sinnaevd Posted June 20, 2006 Share Posted June 20, 2006 where can i find the best price for the full traction 6 inch XJ lift. I think that's the kit i'm going to run on my MJ. Link to comment Share on other sites More sharing options...
feerocknok Posted June 21, 2006 Share Posted June 21, 2006 Different rear suspension. Link to comment Share on other sites More sharing options...
sinnaevd Posted June 21, 2006 Author Share Posted June 21, 2006 I know. I will sell of the XJ leaf pack, and have sutom leafs made. Or I should be able to SOA, and that should bring me close to level...might need just a little bit inthe rear but maybe an inch to an inch and a half... Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 21, 2006 Share Posted June 21, 2006 Go steal a main leaf from a dakota pack or such, cut the eyes off, and add it to your packs under the main leaf, should be level. Spring rate will be slightly stiffer, but that's a good thing in this case... Link to comment Share on other sites More sharing options...
sinnaevd Posted June 21, 2006 Author Share Posted June 21, 2006 That with SOA? Or am I missing something?? Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 21, 2006 Share Posted June 21, 2006 Yeah, with SOA. Guess I should have clarified. Link to comment Share on other sites More sharing options...
sinnaevd Posted June 21, 2006 Author Share Posted June 21, 2006 I probably shoul dhave assumed. lol I still trying to learn the ropes That XJ book should be at my doorstep any day now, hopefully that will put me on the same page as everyone Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 21, 2006 Share Posted June 21, 2006 I'm thinking I should read that book at some point. See how many things I've done 'wrong'. Link to comment Share on other sites More sharing options...
sinnaevd Posted June 21, 2006 Author Share Posted June 21, 2006 ur not wrong...just being innovative. lol The good hting is, you have knowledge to make sound decisions off of. I still am completely confused as to "why" certain lift kits are better then others. not sure what I should be looking for Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 21, 2006 Share Posted June 21, 2006 I hate to blow my own horn, but you might read this thread: http://comancheclub.com/forums/viewtopi ... hlight=faq It just covers the basics, and has my opinons thrown in it... I think. Link to comment Share on other sites More sharing options...
sinnaevd Posted June 21, 2006 Author Share Posted June 21, 2006 holy moly..... Link to comment Share on other sites More sharing options...
pingpong Posted June 22, 2006 Share Posted June 22, 2006 that thread just scratches the surface though. Since you don't have a lot of knowledge I suggest you research, and then ask lots more questions before you chunk down the kinda money a full traction kit demands. Link to comment Share on other sites More sharing options...
sinnaevd Posted June 22, 2006 Author Share Posted June 22, 2006 for sure. I am going to be lifting this winter probably, so I still have a ton of time to search. But at the same time, I want to do all my other mods first Link to comment Share on other sites More sharing options...
pingpong Posted June 22, 2006 Share Posted June 22, 2006 What are your plans for your rig, and how do you plan on wheeling it Link to comment Share on other sites More sharing options...
sinnaevd Posted June 22, 2006 Author Share Posted June 22, 2006 I plan on doing mostly trails mud, san dune. Not really into actual rock climbing, but might run some very very small ones up in Norhtern Ontario. So far I, I want to switch over to auto, upgrade transfer case, D44 rear, engage.diengage locker, 4.56 front anf rear, 33 inch tires, 6 inch lift (long arm mostly because I prefer the look). aftermarket bumpers, roll bar, lights etc. lotsa little stuff. I will also have to do a 4X4 conversion, so if I can find a XJ with a d44, i'm guessing that will be a better go because I will SOA the rear n e way. That's it in a basic nutshell... Biggest problem I think I am having (unless everyone can see problems I am going to run into) is that I'm not sure on what manufacturere to buy all my junk from. I've had bad luck buying used parts to actually use in the past...so I am more then likely going to buy most of the stuff used. Only thinkg in concrete right now are TrXus 33 inch tires, with the rims I choose (i forget what they are called) Link to comment Share on other sites More sharing options...
Pete M Posted June 22, 2006 Share Posted June 22, 2006 An XJ Dana 44 won't save you any effort. You'll still need to move the spring perches. Link to comment Share on other sites More sharing options...
87manche Posted June 22, 2006 Share Posted June 22, 2006 Pete M said: An XJ Dana 44 won't save you any effort. You'll still need to move the spring perches. yep, and you can find a Ford 8.8 out of an exploder cheaper/easier and get rear disc brakes with some minor modifications. I've got two here, with brackets. Link to comment Share on other sites More sharing options...
sinnaevd Posted June 22, 2006 Author Share Posted June 22, 2006 are 8.8's cheaper to build? D44 with 4.10's easy to sell? Link to comment Share on other sites More sharing options...
Pete M Posted June 22, 2006 Share Posted June 22, 2006 sinnaevd said: are 8.8's cheaper to build? Sorta. They are newer and so would likely not need a complete overhaul as you can expect with a 20 year old Dana 44. The main good points are disk brakes and they are common in junkyards. Since you're changing to 4.56s, the gears in the axle won't matter so just make sure the one you pick is in great condition with good brakes and intact e-brake cables. Also make sure what ever type of locker you want is available for the 8.8. sinnaevd said: D44 with 4.10's easy to sell? Yes. Link to comment Share on other sites More sharing options...
sinnaevd Posted June 22, 2006 Author Share Posted June 22, 2006 what's a good price for a d44 with 4.10's?? like 200 Canuck? Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 22, 2006 Share Posted June 22, 2006 Up to $650. $200 is a 'good' price. You can pick them up for $100. Link to comment Share on other sites More sharing options...
pingpong Posted June 23, 2006 Share Posted June 23, 2006 Price for a D44 depends on demand in your area. anywhere from 200 to 400 is normal in my area. As for the 8.8 the came in explorers for many yrs. I have one and it is stout as all get out. The factory LSD really isn't that great, as mine failed on the second trip. If you get one with a LSD yo CAN NOT use a lunchbox locker in it. Your only choices are to lincoln lock it, or full locker, or replace to an open carrier and reset-up your gears. Another thing about the 8.8 is the carrier is externally shimmed so it is easier to set-up gears on it, but still not a job for someone with limited skills Link to comment Share on other sites More sharing options...
sinnaevd Posted June 23, 2006 Author Share Posted June 23, 2006 now I already have the D44. If I don't plan on really rock crawling, will I need the Disc rear?? Should I just keep the D44 I have and rebuild it accordingly? Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 23, 2006 Share Posted June 23, 2006 Just use the D44. Disk brakes are nice, but not really a huge deal. Link to comment Share on other sites More sharing options...
sinnaevd Posted June 23, 2006 Author Share Posted June 23, 2006 plus this is already out of a manche, so it WOULD bolt right in if I wasn't doing SOA, but since I am SOA, and going to do that Dakota thingy you were telling me about to level it off, then I need to cut off the peice that the leafs bolt to and weld new ones in correct??? That's the basic plan? Link to comment Share on other sites More sharing options...
