mjtjnj Posted October 7, 2008 Share Posted October 7, 2008 Well, I replaced every sensor on the vehicle except the TPS and it seems there's a "dead spot" in it now. Had a problem with it a couple years ago, cleaned the connectors and it cleared up. That didn't work this time, so I ordered a new Standard Ignition one. Question is - is it just bolt and go or do I need to make adjustments? Does it come preset, in other words? Thanks Tom :chillin: Link to comment Share on other sites More sharing options...
fiatslug87 Posted October 7, 2008 Share Posted October 7, 2008 You have to adjust it. What year MJ do you have? If It's '90 or older and a 4.0 the adjustment can be found here: http://www.pirate4x4.com/tech/billavist ... manual.pdf the settings are different for Auto and Manual trans. Link to comment Share on other sites More sharing options...
summerinmaine Posted October 7, 2008 Share Posted October 7, 2008 If you could just shoot that TPS Report right over to me, that would be great! :brows: Link to comment Share on other sites More sharing options...
fiatslug87 Posted October 7, 2008 Share Posted October 7, 2008 If you could just shoot that TPS Report right over to me, that would be great! :brows: Doesn't the link work for you? It should open the RENIX manual in PDF, then just save a copy to your local drive. Link to comment Share on other sites More sharing options...
BLHTAZ Posted October 7, 2008 Share Posted October 7, 2008 If you could just shoot that TPS Report right over to me, that would be great! :brows: Doesn't the link work for you? It should open the RENIX manual in PDF, then just save a copy to your local drive. That is too good... He didn't mean that literally...it's a quote from a very funny movie called Office Space (I believe is the name). Link to comment Share on other sites More sharing options...
BLHTAZ Posted October 7, 2008 Share Posted October 7, 2008 OK...here is the "how to" part from the FSM on adjusting the Renix era TPS... THROTTLE POSITION SENSOR (TPS) 1) Turn ignition on. Check throttle position sensor input voltage. Connect voltmeter negative lead to terminal "B" (M/T), or terminal "D" (A/T) of sensor connector. Connect voltmeter positive lead to terminal "A" (M/T and A/T) of sensor connector. NOTE: On (A/T) models, connector terminals are identified byletters molded into back of connector. On all models, do notdisconnect TPS harness connector. Insert voltmeter testleads through back of wire harness connector. On somemodels, it may be necessary to remove throttle body fromintake manifold to gain access to sensor wire harness. 2) Move and close throttle plate completely (M/T and A/T). Ensure throttle linkage contacts stop. Note voltmeter reading. Input voltage at terminals "B" and "A" (M/T), or terminals "A" and "D" (A/T) should be 5 volts. 3) Return throttle plate to closed throttle position (M/T and A/T). Check sensor output voltage. To do so, disconnect voltmeter positive lead from terminal "A" and connect it to terminal "C" (M/T), or terminal "B" (A/T). 4) Maintain throttle plate in closed position (M/T and A/T). Ensure throttle linkage contacts stop. Note voltmeter reading. Output voltage should be .8 volt (M/T), or 4.2 volts (A/T). 5) If output voltage is incorrect, loosen bottom sensor retaining screw and pivot sensor in adjustment slot for a coarse adjustment. Loosen top sensor retaining screw for fine adjustments. Tighten screws after adjustment. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted October 7, 2008 Share Posted October 7, 2008 AW4 TPS Adjustment - http://www.greatlakesxj.com/tech/TPS.html Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted October 7, 2008 Share Posted October 7, 2008 Taz can you put that in the DIY section? Link to comment Share on other sites More sharing options...
BLHTAZ Posted October 7, 2008 Share Posted October 7, 2008 Taz can you put that in the DIY section?Good idea...I'll do it right now. :cheers: Link to comment Share on other sites More sharing options...
summerinmaine Posted October 8, 2008 Share Posted October 8, 2008 If you could just shoot that TPS Report right over to me, that would be great! :brows: Doesn't the link work for you? It should open the RENIX manual in PDF, then just save a copy to your local drive. That is too good... He didn't mean that literally...it's a quote from a very funny movie called Office Space (I believe is the name). Yeah, sorry about that. My sense of humor occasionally takes a sharp turn. Link to comment Share on other sites More sharing options...
mjtjnj Posted October 8, 2008 Author Share Posted October 8, 2008 Thanks, guys; after reading up on it a bit, I realize it was a dumb question -- thanks again!! Tom :oops: Link to comment Share on other sites More sharing options...
BLHTAZ Posted October 8, 2008 Share Posted October 8, 2008 Thanks, guys; after reading up on it a bit, I realize it was a dumb question -- thanks again!!Tom :oops: None of that now...look at rule #2 ;) http://comancheclub.com/forums/viewtopic.php?t=1239 Link to comment Share on other sites More sharing options...
