axle swap
You'll need to purchase a right side brake hose for the left side, and run new brake lines on the axle. You'll also need shock mounts. And the flanged adapter for the pinion (grab while getting the axle). Oh, it's also a hair narrower than a stock axle, a set of spacers would be nice.
If you decide to go with the 8.25" XJ axle, be sure it's from a '97 or newer XJ. The older ones are 27 spline just like the D35, and the shafts are the same diameter. The '97 and newer use larger shafts and have 29 splines.
The 8.25 is worthwhile if it's free (mine was), otherwise buy an 8.8. I just got done swapping one into my MJ, well, almost done. Most popular gear ratios are 3.55, 3,73, and 4.10 and can be found with a limited slip. Picked mine up complete for $100.
