$500 MJ after a day's work
Just got done tracing down gremlins, the PO butchered the tailight wiring, which in turn fried everything else. So I worked on putting it back to 'factory' wiring. Everything works (lighting) like it should and I have dash lights. Sprayed the front and rear flat black, gonna undercoat the 6-8" on all body panels.
Here it is....RUSTY
213,000miles and 2.5 auto command trac 1986 beaut. and still ticking. Did a full tune up and gotta re-seal the diffs, but other than that....should be good for winter fun.
Wouldnt mind lifting it later on.
You're right. This thing is what a truck should be......only power brakes, steering and heat. I want to get some old wrangler steelies and 33's and a lift, but that's it.
Possible olive drab pray can job after some rust treatment.
It already has the custome aluminum floorpan mod on the driver's side,,,,,,
It's already gutless, so I'm not worried about speed or anything, just some mild trail work and winter fun.
