Was the 1987 comanche a uni-body?
You can plate the unibody, add extra crossmembers, or add rock sliders or an exo cage. Oh, bumpers help in the front too.
You don't need to bother with a MJ unless you're going to be really evil to it. Or it's in bad shape.
Plating it is a b*@$£. If you take 3"x3"x.250" box (IIRC) and split the top off of it, it will slip over the uniframe rails from the tranny mount area back. Drill a lot of holes in the box and rossett it, then stitch the top. From the tranny mount foreward I used 3"x4"x.250" 90* angle and 3"x.250" flat bar and built my own 'warped' channel to fit the contours of the body. Again, rossets and stitch welds to hold it in place. From there foreward I'm not totally sure what's best, probably taking more flat bar and rossetting the hell out of it.
