alex_and_sean Posted September 15, 2008 Share Posted September 15, 2008 Well I was welding on some new floor pans and some other associated replacement metal along the drive cavity from inside and I caught some wires on fire. After putting out the fire and cleaning my shorts, I discovered it is a 4 wire run that goes from the transfer case to the front of the truck. Is this the two send speed sensor cable? One of these days, this project will be done and we can go jeeping (I hope) assuming I don't catch something else on fire too. Cheers Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted September 15, 2008 Share Posted September 15, 2008 I'm not positive but I believe that's your front axle disconnect and I don't think you need it. Ask Taz to ellaborate because I haven't dealt with it yet. Link to comment Share on other sites More sharing options...
Pete M Posted September 15, 2008 Share Posted September 15, 2008 Are they wires? Or colorful vacuum tubes? Link to comment Share on other sites More sharing options...
alex_and_sean Posted September 15, 2008 Author Share Posted September 15, 2008 Good call Pete. You da man! :bowdown: I went back under and looked closer and they are 4 vacuum lines (red, blue, green, yellow) that connect to the 231 just below and forward of the spedo cable. Obviously I am going to have to replace this, but what am I looking for (besides having more control of my welding). Sean Link to comment Share on other sites More sharing options...
Pete M Posted September 15, 2008 Share Posted September 15, 2008 No need to replace the fragile vacuum lines. Just cap them off and then alter the CAD to be engaged all the time. Simple and reliable. :D Link to comment Share on other sites More sharing options...
BLHTAZ Posted September 15, 2008 Share Posted September 15, 2008 No need to replace the fragile vacuum lines. Just cap them off and then alter the CAD to be engaged all the time. Simple and reliable. :DExactly...shim the CAD over in the locked position and forget about those tubes :cheers: You will need to locate the vacuum source and cap it off though ;) Link to comment Share on other sites More sharing options...
alex_and_sean Posted September 16, 2008 Author Share Posted September 16, 2008 Cool. If no ill effects, then I will do this since from what I have read this is a weak point (one of many). I have poked around on the site and found several threads discussing this. It seem pretty straight forward. Is there a specific write up available? One thread metioned a write up but I was not able to find it. I think I need a few beers now. :cheers: Link to comment Share on other sites More sharing options...
