mvusse Posted September 5, 2008 Posted September 5, 2008 In your opinion, what's the largest amount of lift that will still look okay with 29" tires (235/75R15) without the tires looking too small under the vehicle? Income tax should allow me to lift my truck next spring, but new tires are going to be out of the budget for at least a year after.
Motion Offroad Posted September 5, 2008 Posted September 5, 2008 Depends if your running the flares or not. 3" would be about as high as I'd go with that size tire.
WahooSteeler Posted September 5, 2008 Posted September 5, 2008 In your opinion, what's the largest amount of lift that will still look okay with 29" tires (235/75R15) without the tires looking too small under the vehicle? Income tax should allow me to lift my truck next spring, but new tires are going to be out of the budget for at least a year after. Even if yours is a DD, there always seems to be a good deal on some used tires, either local or on Jeepforum.com, just a thought.
Eagle Posted September 5, 2008 Posted September 5, 2008 In your opinion, what's the largest amount of lift that will still look okay with 29" tires (235/75R15) without the tires looking too small under the vehicle? 235/75R15s are almost exactly the same size as 30x9.50s. You don't need any lift to run 235s, and IMHO anything more than a 2" budget boost will look silly.
WahooSteeler Posted September 5, 2008 Posted September 5, 2008 Dude, deals like this ALL the time on jeepforum.com. Wheels AND 31" tires for under $200. Shipping from MO to OH shouldn't be bad. I suspect you could have these in hand for $300 or less. I know you're not looking to buy now, but just giving an example. http://www.jeepforum.com/forum/showthread.php?t=600192
BLHTAZ Posted September 5, 2008 Posted September 5, 2008 I would just do a 1.75" spacer in the front to level the truck out and be done with it for a 29" tire. My truck had the 235's on it when I bought it and they rubbed a little bit, but not bad. A 3" lift is going to have a fair amount of space around the tire, but I personally like the look of lots of tire room and I hate the stuffed in look.
mvusse Posted September 5, 2008 Author Posted September 5, 2008 I run a 1.75" spacer in the front right now, as I don't lake the raked look on a 4x4. That should be reserved for a 2wd truck. But when I went to badlands last July I decided I need more lift and would like larger tires. I can't afford both at the same time, so I'd have to get the lift first, then the tires. My current tires only have 4000 miles on them, it would be a shame to get rid of them as I don't have another vehicle using that size tire (Suburban uses 285/75R16), and off road every 1/16 tread will help, so I really don't want to get used tires.
chicofuentes0224 Posted September 5, 2008 Posted September 5, 2008 Get a three inch lift. Then throw 31's on when your ready. :cheers:
jeep_freek88 Posted September 6, 2008 Posted September 6, 2008 My MJ has a 3" lift and 30-9.50-15 tires and it looks fine :cheers:
mvusse Posted September 7, 2008 Author Posted September 7, 2008 Thanks guys. The consensus seems to be 3", no more.
