Motion Offroad leaf spring measurements.
This is only used for reference and don't "quote" us on this. As we measured a MJ without rear flares so we're somewhat "guessing" based on what the flare should be. Maybe some who's running our rear leafs who's still got flares can chime in to give you the exact measurement your looking for.
3" Leafs - 23.5"
4.5" Leafs - 25"
3" Leafs - 23.5"
4.5" Leafs - 25"
Maybe this will help. Jeep tech note I.S. 14E explains how to check the ride height on a Comanche. They use the chassis and suspension not the hubs and flares.
Front:
Measure vertical distance between top of axle tube (looks like just inboard of the LCA mount) to the under side of the frame rail. For the passenger side, measure from the axle tube just outboard of the vacuum disconnect housing. The book says for 2WD models the distance should be 6-3/4" +/- 1/2". For 4WD models the distance should be 7-3/4" +/- 1/2"
Rear:
Measure from the top of the axle tube to the underside of the frame rail inboard of the rubber bump stop. For 2WD the distance should be 8.2" +/- 1/2". For 4WD models the distance should be 9.2" +/- 1/2"
So there you have it. That's the official specs.
3" Leafs - 23.5"
4.5" Leafs - 25"
Front:
Rear:
This should be posted on the DIY forum.
