stick built RTI ramp
I had some extra lumber sitting around my house. I used a 16' 2x8 at a 20 deg angle, 2x8 vertical supports no more than 12" on center. Two 4x4's that come out to the sides at 20 deg angles. then an extra 4x4 vertical support, fallowed by a 4x6. The total height is 50" Here are some pictures, I will get some more up when it gets tested.
I will I have a couple 4x6's sitting on the side of my house, as far as collapsing backward the diaganols are at a 20 deg to the rear and a 20 deg to the side, I am going to do the same with the rear..... there are almost enough 16 pennie nails in that to weld it together as it is.
You could make some big plywood triangles and screw them on both sides .Even if they only went from pointed end at start of ramp to about 2/3 of the ramp they will make it way more safe. Also keep it coverd the weather will weaken wood structures fast.
