jtdesigns Posted August 21, 2008 Share Posted August 21, 2008 Hey fellows... whats the right pilot bearing for swapping in a AX-15 to the renix 4.0l? I thought it was covered before, but search came up with a million hits.. 94-96 xj 2wd AX-15 into a 89 2wd Comanche with the BA-10 I believe the the BA-10's pilot bearing dimensions were OD= 1.050 ID= .625 Thank ya much,, jt Link to comment Share on other sites More sharing options...
Pete M Posted August 21, 2008 Share Posted August 21, 2008 Bronze pilot bushing from an 80s era CJ. I forget which engine, but it's a $2 part. The other option was like $10 bucks or something like that. Link to comment Share on other sites More sharing options...
Pete M Posted August 21, 2008 Share Posted August 21, 2008 The guy in that one writeup says he used a bushing from a 73 with the 304. http://www.jeeptech.com/convtrans/ax15swap.html Link to comment Share on other sites More sharing options...
jtdesigns Posted August 22, 2008 Author Share Posted August 22, 2008 Thats exactly the write up I was thinking about Pete,, thanks!!! Link to comment Share on other sites More sharing options...
jtdesigns Posted August 24, 2008 Author Share Posted August 24, 2008 Quick question... what rubber mount should be used with this swap? 94-96 ax-15 2wd into my 89 that had the 2wd ba-10. I going to buy a new mount just don't know which one I'll need... Thanks,, jt EDIT: never mind rock has the same part number for both! :D Link to comment Share on other sites More sharing options...
Pete M Posted August 24, 2008 Share Posted August 24, 2008 An AX-15 needs an AX-15 mount. Don't worry, it's easy to tell the difference. If it costs an arm, a leg, and a kidney, then you have the wrong one. :D AX-15 mounts are pretty cheap compared to BA-10 mounts (if you can even find one). Link to comment Share on other sites More sharing options...
Wildman Posted August 25, 2008 Share Posted August 25, 2008 You should have This mount now for your BA-10- Don't throw it away, TeamCherokee get's $95 for one of those :eek: And what you'll need is a tranny mount for the AX-15 or AW4 - ANCHOR Part # 2625 with 4WD; Trans with MT, 4AT 4 WHEEL DRIVE 2 WHEEL DRIVE with RWD; Trans with MT, 4AT $13.69 From where else...........Rockauto Link to comment Share on other sites More sharing options...
jtdesigns Posted August 25, 2008 Author Share Posted August 25, 2008 You should have This mount now for your BA-10- Don't throw it away, TeamCherokee get's $95 for one of those :eek: And what you'll need is a tranny mount for the AX-15 or AW4 - ANCHOR Part # 2625 with 4WD; Trans with MT, 4AT 4 WHEEL DRIVE 2 WHEEL DRIVE with RWD; Trans with MT, 4AT $13.69 From where else...........Rockauto I searched rockauto for the 95 xj and 89 mj both had the same part numbers, so I was thinking they were the same mount for both. My mount is oil soaked and real gooey like. Staying with the J.E.E.P. philosophy,, might as well buy a new one... :roll: Link to comment Share on other sites More sharing options...
Pete M Posted August 25, 2008 Share Posted August 25, 2008 Any MJ/XJ with the AX-15 should have the same mount. Link to comment Share on other sites More sharing options...
