88manche4x4 Posted August 17, 2008 Posted August 17, 2008 If anyone has the stock hub-to-flare measurements for and 88 comanche 2wd, could you post them? My friend thinks I have 7.5'' of lift on my 'manche but i think its closer to five.
deziped Posted August 17, 2008 Posted August 17, 2008 I've got a lilttle commanche that measures 36-25-33. Whoops, sorry I forgot were talking about MJ,s here.
summerinmaine Posted August 17, 2008 Posted August 17, 2008 17-1/2 front 20-1/2 rear So that's center of hub to lower edge of flare, right?
88manche4x4 Posted August 18, 2008 Author Posted August 18, 2008 Thanks. That means i have about 5'' of lift on mine. no wonder i rub with 33's. Also, how long should i make my rear driveshaft, ujoint to ujoint with my SYE at half slip? I measured my trans thats in there and my 4wd setup thats on the floor, and its 4'' longer. that means i would make the driveshaft right about 32'' - 33'', right? BTW its an 88 Longbed
WahooSteeler Posted August 19, 2008 Posted August 19, 2008 17-1/2 front 20-1/2 rear So that's center of hub to lower edge of flare, right? I assume this is for 4x4's? So, a full 3" of rake up front in stock position.
Motion Offroad Posted August 19, 2008 Posted August 19, 2008 I assume this is for 4x4's? So, a full 3" of rake up front in stock position. Not necessarily "rake", as the wheel wells are not the same from front to back.
Eagle Posted August 19, 2008 Posted August 19, 2008 17-1/2 front 20-1/2 rear So that's center of hub to lower edge of flare, right? I assume this is for 4x4's? So, a full 3" of rake up front in stock position. No, he asked for the measurement on a 2WD. THe 4WD MJ is 21-1/2 in the rear.
WahooSteeler Posted August 19, 2008 Posted August 19, 2008 oops, that he did, that he did. thanks for the info.
summerinmaine Posted August 19, 2008 Posted August 19, 2008 I went out to measure my rig after the info was posted, just to confirm the lift, and realized it wouldn't do much good since I have a 1000# camper mounted in the bed! :oops:
88manche4x4 Posted August 20, 2008 Author Posted August 20, 2008 Can someone with a Longbed with a 4.0/aw4/231 PLEASE measure they're rear driveshaft from u-joint to u-joint? Bonus points if i can get measurements for a 4.0/aw4/242 in a longbed MJ.
Chico Posted September 5, 2008 Posted September 5, 2008 Can someone with a Longbed with a 4.0/aw4/231 PLEASE measure they're rear driveshaft from u-joint to u-joint? Bonus points if i can get measurements for a 4.0/aw4/242 in a longbed MJ. Skippy, You still need this?
Eagle Posted September 5, 2008 Posted September 5, 2008 This may help: http://comancheclub.com/forums/viewtopic.php?t=11693
