maddzz1 Posted August 15, 2008 Share Posted August 15, 2008 Since i have been going thru my truck I have been finding alot of rusted, stripped, or missing screws. Like for the grill, headlights, interior moldings. I want to replace them all with stainless. What grade should I use for things like this? When it says #4, #6, #8 are those the grade? Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted August 16, 2008 Share Posted August 16, 2008 Not likely.. look like the screw size to me... Stainless is the way to go for those small screws for sure!! CW Link to comment Share on other sites More sharing options...
Eagle Posted August 16, 2008 Share Posted August 16, 2008 I agree, you're probably seeing the size designation. Typically, in American/SAE terminology the smallest diameter bolts or screws specific by shank diameter are 1/4". Anything small is a number, with #12 being pretty close to 1/4", #10 being a little smaller, and progressing down in size as the numbers get smaller. Be sure you're looking for the correct thing, though. Many of the bolts and screws on the MJ are metric. Those are also designated by a number, but preceded by an 'M'. The number is the shank diameter in millimeters. For example, the studs on the backing plates for the fender flares need an M5 nut. (Try to find them!) Link to comment Share on other sites More sharing options...
maddzz1 Posted August 16, 2008 Author Share Posted August 16, 2008 Will it list all the bolt/screw sizes in my FSM? Link to comment Share on other sites More sharing options...
Pete M Posted August 16, 2008 Share Posted August 16, 2008 Hahahahahahahahahahahahaha... :rotfl2: ..cough.. I mean, no. We're not that lucky. :( Link to comment Share on other sites More sharing options...
xj92 Posted August 16, 2008 Share Posted August 16, 2008 I end up buying a lot of bolts, nuts, screws, etc. from the local hardware store, but some are hard to find, so when I'm at the pick'n'pull or the junkyard getting something else, I grab as many screws, nuts, bolts, etc. off of cherokees and/or comanches. Just makes it easier in the future and they're usually free as long as I'm buying something else there. Link to comment Share on other sites More sharing options...
maddzz1 Posted August 16, 2008 Author Share Posted August 16, 2008 Hahahahahahahahahahahahaha... :rotfl2: ..cough.. I mean, no. We're not that lucky. :( Maybe would should start a thraed for a list of nut/bolt sizes for? Link to comment Share on other sites More sharing options...
Pete M Posted August 16, 2008 Share Posted August 16, 2008 That's a great idea! I'm putting you in charge of it. :D Link to comment Share on other sites More sharing options...
maddzz1 Posted August 16, 2008 Author Share Posted August 16, 2008 That's a great idea! I'm putting you in charge of it. :D Ill start the thread then maybe you can stickie it for a few weeks so people can add to it then move it to the DIY section. Link to comment Share on other sites More sharing options...
wolfpackjeeper Posted August 16, 2008 Share Posted August 16, 2008 most of the screws used for the interior pieces, headlight bezels, turn signals, grill panel, ect, can all be found at advance auto. They are on the headlight aisle and are called trim retaining screws I think Link to comment Share on other sites More sharing options...
