WahooSteeler Posted August 7, 2008 Share Posted August 7, 2008 True to form for me, I'm scrambling at the last minute to make sure I have everything I need for the Steeler Nation Wrench-a-thon with the Richmond Va chapter this weekend. That being said, can anybody tell me what dimensions my replacement u-bolts need to be for my MT spring packs mounted under a D44? Need the info pretty quick so that I can have some made up and or purchased by the end of the day tomorrow. Hey mjeff87, we should set up a video camera and time lapse it so it looks like a 30 minute episode of Overhaulin at the end of the weekend LOL! Link to comment Share on other sites More sharing options...
johnnyc Posted August 7, 2008 Share Posted August 7, 2008 The tubes are 2.75", so that's the inside diameter. And I believe they usually come in 9" length. Link to comment Share on other sites More sharing options...
WahooSteeler Posted August 7, 2008 Author Share Posted August 7, 2008 thanks johnny c......... Link to comment Share on other sites More sharing options...
WahooSteeler Posted August 7, 2008 Author Share Posted August 7, 2008 my truck is at home, can't look under right now. round our square? Link to comment Share on other sites More sharing options...
watchamakalit Posted August 7, 2008 Share Posted August 7, 2008 my truck is at home, can't look under right now. round our square? Unless you have flipped them you need round ones. Link to comment Share on other sites More sharing options...
WahooSteeler Posted August 7, 2008 Author Share Posted August 7, 2008 that's what i thought, didn't want to ASSume thanks! Link to comment Share on other sites More sharing options...
watchamakalit Posted August 7, 2008 Share Posted August 7, 2008 that's what i thought, didn't want to ASSume thanks! understood. I am just glad to be able to give something back to the site. Link to comment Share on other sites More sharing options...
WahooSteeler Posted August 7, 2008 Author Share Posted August 7, 2008 9/16" bolt? Link to comment Share on other sites More sharing options...
watchamakalit Posted August 7, 2008 Share Posted August 7, 2008 9/16" bolt? That I can't tell you. Sounds right but don't ASSume so. :D Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 7, 2008 Share Posted August 7, 2008 EDIT: JUst saw you have a D44 - IGNORE the below except about doubling your nuts. :cheers: Wahoo, you going to need 1/2" dia. round u-bolts, 2-3/4" width inside-to-inside (ID), and 8" length top to bottom. ASSuming you are installing on a D35 axle and are staying SUA. These are what I used when I installed my MT 5-leaf springs. And don't forget to double up your nuts! :eek: Link to comment Share on other sites More sharing options...
WahooSteeler Posted August 7, 2008 Author Share Posted August 7, 2008 Wahoo, you going to need 1/2" dia. round u-bolts, 2-3/4" width inside-to-inside (ID), and 8" length top to bottom. ASSuming you are installing on a D35 axle and are staying SUA. These are what I used when I installed my MT 5-leaf springs. And don't forget to double up your nuts! :eek: i was told by someone else 9/16's bolt by someone else. going on a D44, staying SUA. so i've been checking around with the same dimensions you mentioned but with 9/16s, not 1/2". please confirm........ and why are thinking about my nuts? :D Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 7, 2008 Share Posted August 7, 2008 i was told by someone else 9/16's bolt by someone else. going on a D44, staying SUA. so i've been checking around with the same dimensions you mentioned but with 9/16s, not 1/2". please confirm........ and why are thinking about my nuts? :D Yes, 9/16" dia. material for the D44 u-bolts. And I'm talking about the U-bolt nuts (two on each bolt leg), not yours mate. :cheers: Link to comment Share on other sites More sharing options...
WahooSteeler Posted August 8, 2008 Author Share Posted August 8, 2008 whew! i was worried they were 1/2" because i already called a shop to fab them at 9/16's. schweeeet. :jump: Link to comment Share on other sites More sharing options...
mvusse Posted August 8, 2008 Share Posted August 8, 2008 You're having U bolts made? They are common enough that I imagine places like Fastenall would have them. As well as just about any car dealership in various sizes. There's gotta be a bunch that interchange with Comanches. I got a set for my Ford and for my D35 from Advance Auto Parts; they have quite a selection in the help section. Link to comment Share on other sites More sharing options...
WahooSteeler Posted August 8, 2008 Author Share Posted August 8, 2008 Called Advance, they couldn't get anything bigger than 1/2" and I need 9/16s. I didn't think of Fastenal until after the fact which is ironic you mention them because just last week I had to get them to order new flange bolts for my tow hooks. This shop is a spring and suspension specialist, that's all they do. They have threaded rod in stock in tons of different sizes, grade 5 and 8 of course. So all they do is pull some stock off a rack and put it on a bender. $46 for all of them in Grade 8 with nuts and washers included. Link to comment Share on other sites More sharing options...
