Shane Posted August 3, 2008 Share Posted August 3, 2008 My MJ has the gauge cluster with the big gas gauge and lights for the other gauges. What all ia involved in switching them to the one with all needle gauges? Is it as simple as unpluging and pluging back in? I know that the mileage will need to be changed, but other than that is it alot to it\? thanks Link to comment Share on other sites More sharing options...
Pete M Posted August 3, 2008 Share Posted August 3, 2008 After securing the right year cluster (what year is your MJ?), you'll need to swap out the temp and oil pressure switches for the proper sending units. That's about it. Be careful with removing the oil pressure switch. If it snaps off, you'll have quite a project ahead of you to drill it out. The Odo adjustment can be done by just about any shop and they'll give you the proper paperwork to made it all legal. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted August 3, 2008 Share Posted August 3, 2008 Yup, That about covers it!! Many of us including myself have completed this swap and there are many writups on it. CW Link to comment Share on other sites More sharing options...
DenLevi Posted August 3, 2008 Share Posted August 3, 2008 It is an easy swap. I must have had a unique situation with my truck though. I did not have to swap out the temperature or oil pressure sending units at all, everything works perfectly and reads just like my old gauges did. EDIT Link to comment Share on other sites More sharing options...
Eagle Posted August 3, 2008 Share Posted August 3, 2008 It is an easy swap. I must have had a unique situation with my truck though. I did not have to swap out the temperature or oil pressure sending units at all, everything works perfectly and reads just like my old gauges did. That's because you had gauges. You just changed to a cluster with a tach, right? The need to change senders is when replacing an idiot light cluster with full gauges. Link to comment Share on other sites More sharing options...
DenLevi Posted August 3, 2008 Share Posted August 3, 2008 No, I had the big fuel gauge on the left, speedo on the right cluster with idiot lights. Just like this one , (pic taken from another thread.) This is what I have now. Strange it works fine with my truck without changing the senders? Honestly I'm not sure why but all my gauges are reading correctly. Perhaps the PO had replaced the sensors at one point with the variable ones. Sheesh I guess its true.... every once in a blue moon something actually goes right? Link to comment Share on other sites More sharing options...
james750 Posted August 3, 2008 Share Posted August 3, 2008 check out this link, it tells how to do the odometer rollback yourself if need be. http://www.naxja.org/forum/showthread.php?t=921205 Link to comment Share on other sites More sharing options...
