lennyKatan Posted July 29, 2008 Share Posted July 29, 2008 My 89 Comanche is in need of floor pans. Any ideas out there besides a match and gas? I got some steel 16g and started to remove what is still conected to the good part of the floor. I also need to replace the rockers. If I could learn how to post some pic's of what is left of the floors I will for your enjoyment. thanks here are pic's Link to comment Share on other sites More sharing options...
WahooSteeler Posted July 29, 2008 Share Posted July 29, 2008 http://www.shermanparts.com/ you can get fairly good fitting replacements here if you don't just use your own steel. Link to comment Share on other sites More sharing options...
aemsee Posted July 29, 2008 Share Posted July 29, 2008 I checked out the sherman parts site. They have cherokee and comanche pans listed as the same. Aren't XJ and MJ pans different? Link to comment Share on other sites More sharing options...
WahooSteeler Posted July 29, 2008 Share Posted July 29, 2008 yes, XJ and MJ pans are different. there have been some other members here who have gotten pans from them and supposedly they do have true MJ pans. however, i remember reading that you have to remind them several times while ordering that you want MJ pans. that being said, i also remember someone commenting in the same thread that the XJ pans still worked pretty good with a little hammering and modification. i would suggest you do a search on hear for "floor pans" or "sherman" and you should find more detailed info. Link to comment Share on other sites More sharing options...
maddzz1 Posted July 29, 2008 Share Posted July 29, 2008 To post pics you need to put them on a hosting site like photobucket. Then you have to put the link between the img tag. Someone else can explain that part better. Link to comment Share on other sites More sharing options...
Wildman Posted July 30, 2008 Share Posted July 30, 2008 I got some steel 16g Wow :eek: That's some heave metal there for making panels :eek: What you want to look for is some 22 ga sheet metal for repair panels, and if you not going to weld them in, like use sealant and pop rivets, get some Galvanized sheets. This is one place I've had bookmarked- http://www.rustrepair.com/BODY_PANELS/o ... HEROKEE.84 And then there's Keystone and Continental if there near you, but I don't think either one carry the floor pans. The floor pans are not that hard to make, and if your carpet or mat is going back in.......easy to play with, and not have perfect :roll: lets put it this way, the last time I priced a sheet of 22 ga, 4 x 8 it was about $26, the pans are well......more that that, so you can make about 5-6 floor pans out of one sheet.........do the math :roll: Link to comment Share on other sites More sharing options...
