Couple Questions
LOL!!!
I am in over my head fella's :nuts: ......and I love it!! jamminz.gif
I ordered that XJ builders guide thingy that Pete's MJ is in. That will be a big help as well??
and jage, your link didn't work is that's what you were trying to add, so when you get a moment would u mind fixing so i can look?
  • Replies 58
What are you in China or something? :)
The link works fine for me. :hateputers:
Just put:
lower control arm drop
in Google and it's the 3rd thing. Rubicon Express comes up 4th. Unless you're using Google-China of course!
I ran the RE drop brackets for over a yr, and I bought them used. They work great with stock control arms, and 6.5" Rusty's coils. The only problem I had with the drop brackets is that they use up sone of your ground clearance. Not much, but if you wheel like I do, every bit counts :brows:
I don't know wnyone wheeling TNT's kit, the only Problem I see with it, is that it is a radias arm style kit. Personally If I was going to spend the money they are asking for that kit, I would want a parrallel 4 link.
The terra kit, is a parrallel 4link. Dirty Manche was right it uses brackets, but it is real easy to fab up a flat skid, if you have enough skills to install the kit. BY NO MEANS IS THIS A TERRA ENDORSEMENT, I only paid 200 for the LA upgrade kit, and at the time it was beyond my tool level to fab something up like that.
Again RESEARCH is key to something like this. Personally If I had to do it all over again, I would build my own, or adapt a Radias arm setup like Pete did
LOL... my fault I was trying to use ASCII art, but the / in this font is too steep so I used "Code" to make it more of a 45° angle. :nuts: I'm not sane. What can I say.
