SuperWade2 Posted July 22, 2008 Share Posted July 22, 2008 Has anyone had any luck finding a good color matched spray... talking for a fairly small section...The lower flat black section of the XJ front Fender (under the trim) that I'm installing on the MJ once I figure out how to get it off (a couple badly stripped screws that I probably need to drill out). I know the color "match" is not going to be perfect, but something close and white will be better than a black section on an otherwise all white truck SW2 Link to comment Share on other sites More sharing options...
jtdesigns Posted July 22, 2008 Share Posted July 22, 2008 Get you a airbrush kit.. There cheap and you can use regular auto paint in them.. Link to comment Share on other sites More sharing options...
Motion Offroad Posted July 22, 2008 Share Posted July 22, 2008 That black section is actually a "tape" type thing. Pull the side molding off first, than if you use a heat gun you may be able to peal it all off, exposing the original white under it. Link to comment Share on other sites More sharing options...
SuperWade2 Posted July 22, 2008 Author Share Posted July 22, 2008 That black section is actually a "tape" type thing. Pull the side molding off first, than if you use a heat gun you may be able to peal it all off, exposing the original white under it. Thanks MO, I'll look at that... I think I have some of PinStripe Eraser left also I could try if that's the case... i was under the impression that the lower section was painted, but hadn't looked real close (as I still don't have the Fender off the truck yet...) SW2 Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 22, 2008 Share Posted July 22, 2008 I know you can of Xylene, that should take the tape residue off without harming the paint. Link to comment Share on other sites More sharing options...
Sir Sam Posted July 22, 2008 Share Posted July 22, 2008 For repainting the lower trim just use flat black trim paint. Link to comment Share on other sites More sharing options...
SuperWade2 Posted July 22, 2008 Author Share Posted July 22, 2008 For repainting the lower trim just use flat black trim paint. Cept I want all white, that screenshot is the doner xj. My mj is all white Link to comment Share on other sites More sharing options...
Sir Sam Posted July 22, 2008 Share Posted July 22, 2008 For repainting the lower trim just use flat black trim paint. Cept I want all white, that screenshot is the doner xj. My mj is all white Oh, now I understand. In that case you can just peel off the plastic sticker, use a heat gun and some patience. Link to comment Share on other sites More sharing options...
