anybody wants to help, i'm going outside to start on the mj. I'm doing the soa and new shocks on the rear ill take all the hands i can get to help
If gas were to cost what it did 5 years ago, there'd be no problem. You live about an hour 45 straight up 250 from me, but nowadays that'd be $35 in gas.
Good luck, though, and stay safe! :cheers:
soa is done just need to remount the shock mounts a little lower rear is 1.5to 2 inches higher than the front and i know i will get some picks of it and upload them
:cheers: Great job!!
I have got to get a welder. The last time I welded...mig & tig were not an option :eek: . Guess I will have a little learning to do when I get one.
the guy that runs the 4x4 shop told me to set it up
draw an imaginary line thru trans output shaft and pinon and make them parell to each other
The rear pinion should be set at about 2 degrees low, not pointing directly at the ouput. It will raise up when you accelerate so it needs to be slightly lower to accomodate that.
when Pat and I SOA'd my MJ, we set the new perches parallel to the factory ones....that keeps the same pinion angle relative to the TC output.
Lookin' good bigD :cheers:
Jeff
BLHTAZ
both output shafts are parallel to each other
OK...so you meant that you didn't "turn it up". I took it as you made the pinion parallel to the drive shaft and the pics kind of looked like that too. Sorry if I misunderstood, but just wanting to be sure. :cheers:
ya pic is at a bad angle and wasn't welded yet when pic was took
i did my reserch befor i started
i just need to trim front fenders and relocate rear shock mounts then start on bodywork :cheers:
