After changing my oil yesterday, i noticed that my floor pan was turning to swiss cheese on both the driver and passenger foot areas. After searching the dealer inventories and after market sources, I found that there are no new floor pans available. Is there any way that an XJ floor pan will work?
I have an 87 MJ with the 2.5, 5spd and 2wd. i love this truck and I'ld hate to see her go to the bone yard.
Any thoughts would be greatly appreciated.
Thanks.
I called Daveys Jeeps in Ohio and they said XJ floor pans would not work.
I figured that the are others out there that are in or have been in the same predicament. So I thought that I would ask.
It is slim pickings in the bone yards near me. I will have a chance to look in one on Sunday, but I don't think that there will be any 2wd models around here.
so I guse using sheet metal like i did was not the right way :oops:
Or it proves me to be the backwood redneck that I am :clapping:
mainemj don't feel bad, I cut the top sheet metal out of a Caravan for my floor pans, works pretty good. I still have some extra for other projects. :brows:
I say weld in some expanded metal over the opening and cal it good :nanner: That way you can see what is hanign you up :evil: I am getting ready to drill 2.5 inch holes in my floor boards on both sides so I can see where my tires are on off chamber stuff
crosscanadaparts.com has floor pans listed for the MJ, picture to show what they look like, canadian dollar for all you americans out there. not sure if it is what your looking for but i thought it was worth mentioning.
