bhawkin2
    West Jefferson,ohio
  • Interests
    4x4's
bhawkin2's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. mainemj don't feel bad, I cut the top sheet metal out of a Caravan for my floor pans, works pretty good. I still have some extra for other projects. :brows:
  2. I'll give it a shot over the weekend an see how it works.
  3. Its funny you say that I had my dash cluster out a couple of weeks ago to hook up my Manual gauges I'll have to check that to. Thanks
  4. Let me know if lubing up your speedo cable works mines bouncing around alot to. I think my Gas gauge is not working either, all my dash lights work though. Mine is also a 86 8)
  5. We have an exhauset bender at work, so we play with all kinds of mufflers an tail pipe configurations on our down time. Boss thinks it helps us learn. :brows:
  6. Do they have a website? Trying to see what they got,never heard of them before.
  7. I know how to set up Diffs. Thats what I do for a living,trans,transfer cases an Diffs. I figure I could use it for a while an then sell it on ebay an recover some of my money. Thanks for the help guys I'll probably pull the cover to be 100% sure.
  8. I have my 86 Comanche 4x4 Dana 35 Rear. My Question is, Is it a non C-CLIP rear end? I have the op to buy a ARB air locker for $150 plus a$100 for the Compressor so $250 for the pair but its for a Non C-CLIP rearend. I don't want to spend that kind of coin on something thats not going to work on my truck. Is there any way to tell with out pulling the cover off the diff? :D
  9. bhawkin2
    STOLEN!
    Thats SUCKS a Big one!!!!!!! Sorry an I hope you get it back in one piece!!! :cry:
  10. I think I would go with the AAL also. A 9" shackle is a long Chunk of steel.
  11. Has anyone used the NEW Posi lock, it has no cable just lockes the collar on the axle shafts permanatly it sell for around $100 instead of the cable operated one for $190.
  12. Feel free I've been all over this thing! :D
  13. I also have a 86. Mine is 2.5 AMC,904/207AMC,dana30 front,Dana 35 rear they are 3.54 gears. Your truck is pretty much Identical to mine except mine is Blue an no fancy stuff.
  14. PB Blaster is a life saver sometimes :D I should have my spacer's by the end of the week, if i get them in i'll post some before an after photos.
