M2 CARBINE
Everything posted by M2 CARBINE
  1. M2 CARBINE
    Wtb Parts
    Looking for a 4wd AX4 or AX15 with or without TC on the cheap willing to pay for shipping . Thanks
  2. I'll also take a 88-89 without the c101 but will need the ECU/PCM. Thanks
  3. 87's must be rare Done found 8 89's 3 88's 2 90's
  4. Still on the hunt.
  5. Still looking for a harness with the C101 on the upper drivers side firewall. Thanks
  6. Still looking
  7. Looking for a MJ or XJ Renix era 87 thur early 90 2.5 engine harness Manual trans.
  8. Think ill just turn it into a trailer.. Thanks for the help.
  9. Sorry about the confusion the motor is not seized and I don't know if its getting spark at the plug kinda hard to turn the key and see if is sparking. Thanks
  10. I don't hear the fuel pump prime when i turn the key but i spray starter fluid/ gas into the Intake and turn the key and no turning over just crank and as for spark everything has been replaced and rechecked with volt meter and everything checks out good. I'm lost and confused!
  11. Well upgraded all the grounds cleaned the C101 again my god that thing was still dirty changed out the CPS,plugs,coil,ignition control module from my DD XJ and no change.
  12. I did it yesterday with cleaner along Q-tips and tooth picks and no change. Starting to get frustrated.also cleaned the grounds thinking of upgrading them to 4 gauge just to see if that will do something. Thanks
  13. All the wires are on and tight. Turn key and it cranks but no sign of trying to turn over or run.
  14. Any ideas?
  15. Okay i haven't received the fuel pump yet but i checked all the fuses,relays and grounds and still can't figure out why its not turning over. It's very werid reminds me of when i had a 93 XJ i did a tune up on and after words wouldn't turn over i put the old distributor back on fire right up went and exchanged it samething went to 3 other big box stores and none would work ended up going to chrysler and paying $25 for one put it on and boom worked great. any input would be great.
  16. Hey guys Just picked up a 1987 Comanche 2wd 2.5L 4 speed floor shift manual and its not turning over when i turn the key i don't hear the fuel pump at all so thats the first thing i gotta get is the inline 4 the same as the inline 6? also if i put a little gas or starter fulid in the TB it doesn't even try to run. The guy i got it from said he replaced the following spark plugs,ignition coil,CPS,distributor,rotor,starter. thanks for the help
  17. The parts are from a japanese arisaka I don't know which type 99 or 38 not worth much unless its from a specific series. Check out gunboards.com
  18. 1987 Short bed Base Model VIN: 1JTMG6411HT127108 Location: South Atlanta, GA Status: Pull A Part, Junk yard Specs: 213,628 mi, 4.0 4 speed 2wd, Bench Seat, Black interior Black exterior,D35 No exciting Options
  19. Wow the xj has a fog light switch too.
  20. silencer? Like for a muffler? I need it for parts for a another mag lite my lense head got run over.
  21. Hello Looking for a broke 3 cell D mag lite batterys acid damage is ok any color. Thank you Robert
  22. great tint pre cut easy. http://www.ebay.com/sch/tint-pro/m.html?_nkw=comanche&_sacat=0&_odkw=&_osacat=0&_trksid=p3911.c0.m270.l1313
  23. M2 CARBINE
    BIG NEWS
    For anybody that wanted to know. Atlanta South 1540 Henrico Road Conley, GA 30288 Phone: 770-242-8844
  24. I order some factory police xj parts from them back in 07 fast shipping from what I remember.
