dakal
Everything posted by dakal
  1. i appreciate the fab work, but its still a chia pet. i'm sure people don't like what i'm doing with my mj, but its mine and i'm having fun. and as ben stiller said in zoolander; i am still so good looking. :bowdown:
  2. cw: you and eagle put it just right. our country is built on the backs of those who toiled for it!
  3. yes
  4. i welded a small bar the length of the manifold. its a couple of inches from the top of the manifold. no more cracking. this was after welding a couple of cracks. also cleaned up by porting where ever i thought it needed it. poor mans header. :brows:
  5. to all those that don't care, up yours!!!!!!!!!!!!!!!!!!!!!!! :USAflag:
  6. it grows on you, like a chia pet.
  7. dakal
    WTF
    words fail me :shake:
  8. cool or maybe hot
  9. need picture please
  10. got ya. i'm going to use .095 and we will see what happens...
  11. looks good. did you smooth out the wheels so there wasn't a place to hang up the pipe?
  12. looking good. i like the black look.
  13. welcome to the club!
  14. he put what i was thinking very well. everyone of our enemies forgot about middle america. truth and justice will prevail!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  15. uuggg
  16. dakal
    Hello from ICEBOX
    welcome back and welcome from oregon.
  17. the no service company.
  18. good luck. sometimes the simplest stuff ends up...
  19. they are heat treated. they are from a hardware store. only nuts, bolts, rivets, stuff like that, drill bits etc.
  20. i'll post a pic when i get there. i'm making petals, a dead petal, finishing the wiring clean up, changing the clutch(leaking) master, running wire for the new lights and fixing the windows at the same time. you know, easily bored, so this keeps me going forward. :bowdown: to myself. 3h
  21. this is a pic of the electric sender for the ax-15 which is for any trans from what i gather i am removing the senders and replacing them with the autometer senders. i will have a full gauge --- and the senders including the oil pressure sender in the classifies soon. 3g
  22. this is a new installment of a old topic. today i sorted out a last problem with the new wiring and it started and runs :brows: greeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeat!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :brows: :banana: :banana: :banana: :banana: :banana: :banana: :drool: :drool: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: two things i learned. remove the grounds from the engine block, thats next to the oil filter and clean them for good contact. the other, remove the plugs from the computer and spray contact cleaner on the male and female terminals. let soak, then take them in and out a few times. let dry throughly, then reinstall. as a maintenance tip this could or will help drivability problems :D 3f
  23. eureka :clapping: :clapping: :clapping: :clapping: :clapping: :clapping: :clapping: turn signals work. in order for the new turn signal indicators to work they said i needed to wire a three prong flasher up instead of the panels two prong. so i bought a brand new three prong flasher and a holder. wired them up. when the flashers didn't work, we decided to buy a new flasher. did so. installed it. still didn't work. when i called ron francis they told me how to dewire the three prong and use the two prong. thats when it worked. i bought one flasher from napa and one from kenecks? auto stores. what are the odds. so screw it. i'm leaving as is.update: tried the lights today. tail,brake,parking lights work. the toggle switches worked. :clapping: :clapping: :clapping: :clapping: :clapping: :clapping: :clapping: :clapping: :clapping: :clapping: :clapping: turn signals are hooked up as per directions but a wire isn't right. the directions have a mistake so will call ron francis monday. i hooked the front parking light to be a turn signal and that works. its great to be buttoning everything up. bulbs etc. with the motor; finishing the fuel pump wiring, then i think its good to go. i turned the key to find prestart and it cranks, thats good. when it runs, going to get rid of useless wires in engine bay, than will take photo of engine bay, passenger side. then its cleaning up the wires inside to look good. :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: i was really worried about all this redo working. so i'm glad for the progress. :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: my first complete wiring job and if works. RON FRANCIS IS THE MAN! :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: need to get a electric speedo wire next. tomorrow i cut the holes in my $61.00 piece of plastic for the dash. no mistakes 3e
