jeepers
Everything posted by jeepers
yea yea ,it can't be done .an ax15 behind a 2.8,3.1,3.4 ,mines a ht 3.4 sho. well guess what ,it can be done and i did it check it out in mj tech ,ax 15 conversion. thanks guys
ok i have made a 90 ax15 fit behind a 2.8/3.4 . it was alittle work but i made it happen. ok first i got a90 cherokee 4x4 trans,a 98 tj front bearing retainer and a dodge dakota 96-00 bellhousing. took the bellhousing and front trans housing to a mechine shop. had 3/8s of the front ot the bell and 3/16 off the rear of the bell .on the front of the trans i had them take off an 1/8 on the outer edge only ,leaving my bearing surfaces alone. i ordered a clutch disk from KY clutch . ok at this point you can install your ax15 behind you 2.8,3.1,3.4 and a few other motors i dare not mencion. ok now to the trans mount . i took a 3/16 plate and drilled out my trans patten and my cross member pattern into the plate. for an isolator i used 4 shock bushings and washers ,above and below the 3/16 plate. works well so far . ok now to the transfer case linkage,,, i used a 93 cherokee lower linkage(from the t case to the cross arm) bolts rite up .now the bracket that bolts up to the tranny is to short....ok turn it over and cut it in half,use the upper half of it ,bolt it to the trans using the bolts on the center of the trans.its perfict :wrench: ok now on to the input on the t case 23 splines,long shaft ,is what you need in the np207.ok by this point you can use your ax5 shifter in the trans. every thing else is a bolt up item. drive shafts front ,,will bolt back in as is,,,rear ,,remove 1 1/2 inches for mine as I'm running an amc 20 in the rear . i hope i have explained this as corretly as possable,,,if it works for me ,guess what ,it will work for you
well i got the bell housing and tranny front housing back today. a 3/8 off the front of the bell and 3/16 of the rear of the bell,and an 1/8 off the front of the tranny to bell housing face. i came up with my 3/4 into the end of the crankshaft as i was looking for. an 1/8 spacer behind the flywheel ,will allow mt clutch disk to be splined up 13/16 of and inch,,,almost a full spline up. i do have pic on photo bucket now for this write up and will post them tomarrow. along with a step by step write up thanks guys :wrench:
well spoken SIR SAM i killed mine in my drive way... lol my wife was driving.. 44,,,20,,8.8,,,60,,9inch all great swaps :popcorn:
Mnkyboys 89 Comanche project
jeepers replied to mnkyboy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I'm thinkn of one simalur .forgive my spelling. but doing MJ ,underneth the JEEP 1/2 scale . patatotize what you love :dunce:- 798 replies
- 2.5l
- supercharged
- (and 7 more)
my amc 20 came dissasembled,in amc crates. gave a pretty dime for it . but hey i got all the goodies at one time . took me a day or so to set up and get it in ,but no worries.that was 3 years ago ,still rolling along :cheers:
jeep beach??? wheres that we love to play in the sand down here in lousiana :D
I'm here in the good ole la also .. try catahoula recreation in sissily island.
:popcorn:
thanks garvin .. :agree:
ok i got it now il lpost up my pics in the pm . thanks all
nice . keepum comming .. the 44 front sounds good to me .
thanks . ill give it a shot
nice :popcorn:
ok i regestered my my mj here but i couldnt post pics ... or post my rides at the end of a post,as i do with my signature.. can anyone help ?
wow i heard of them and seen one once but when i needed one...no where to be found :bowdown:
ok its a known fact you favor what you run. but if you had to swap up what would you run, ill go first . my 35 dana went south faaaast after sitn in the swamp fo a year(before i got the truck) so i found a metric ton amc 20 package dressed it well. you know disk brakes, mossier one peice axles,a detroit locker,yukon 4.10 gears and some redline 75w140 lube. how about yall fellas................ :popcorn:
hey thats an idea . lets try it
my amc 20 came with the metric ton package in 85- 89 . and there for was a bolt in no ?s ask
well geonofast.. you are part right. no i didnt kill it with a 2.8 (if you read the 1st post) ITS A GM PREFORMANCE HT3.4 SHO sho stands for super charged hi output ,punchn 280 hp and 308 torq to the rear wheels and have the dyno slip to prove it. the 2.8 altho dependable couldn,t pull the hat off your head. :rotfl2: granted i drove it for 9 years before a full restore. the 3.4 is 190 hp over a moded 2.8 but in a bolt in package... as for the ax5 SLUSH BOX ive had my wife kill 1 in the front yard in my rock garden . yea rock garden in lousiana. this is just my preferance and have seen many many ax5s bit the dirt on baby stuff .ask any jeeper ax15 blows ANY AX5 to ****
86 long bed X package ,tilt ,cruse ,cold ac, 5 speed ax15, 4 inch skyjacker lift, 2 inch terra flex revolver shackels, amc 20 rear with disk brakes and detroit locker .4.10 yukon gears and mossier axels ,207 t case ,dana 30 front cromolly axel shafts,ox locker,4.10 yukon gears,a new HT 3.4 SHO v6 headers ,msd ignition ,flowmaster , fully restored ...house of kolor ..triple metalic black/5oz of baby white pearl..burgandy red interior ... costom bumpers with 2 inch recivers front /rear wired for cradle stile winch...rally roll bar with 4 kc lites ....apply named.............the black mule. its my dream truck and also my daily driver.
:thwak: ok i got my solution today at my local machine shop. thank god i know the owner well . here's what ima do ok the 96-00 dakota bellhousing ...we gona mill a 1/4 of the front,a 1/8 off the back. on the ax15..the front housing where the bell bolts up theres a 1/4 inch riser there ..it is gona get milled out for a total of 5/8 this should ..in theory give me my full spline into the clutch disk and 5/8 of an inch into the pilot bearing. I'm supposed to getit back later this week .ill try to post some pics so the rest of you 2.8 guys can stop killing those cheasy ax5s :thumbsup: as i have
:bowdown: wow i m a big fan of retro styling . thanks guys awsome jeep . better than the patriot idea..lol
:thumbsup: awsome job on that truck killer headliner- 798 replies
- 2.5l
- supercharged
- (and 7 more)
The worlds Fastest Comanche
jeepers replied to Worlds Fastest Comanche's topic in Member Projects: Your Comanches
:popcorn: i want your recipe after you make that kinda power .my yj would love it
