bobby m
Everything posted by bobby m
yes possible, not safe but possible. if the diaphram in the booster is bad then you'll just have harder to push bad brakes.
The other night i was driving home and my 89 just went dead. when i say dead, i mean the engine shut off, the headlights,turn signals, braka lights, the radio, everything else electrical just quit. the only thing this truck would do is crank the engine, not start just turn over. After checking all the fusible links, I started chasing wires to see what happened, long story short, run a new ground wire from the battery to the body.Not only did that fix the problem but, my voltmeter has stated working. I told tou all that so i could tell you this, if your voltmeter lies to you like mine has since i bought the truck, tou can fix it by running a new body ground.
i would avoid the rivits, unless it made me feel better after i welded it. the 110 fluxcore should be fine just go slow and stitcth it in good.
How hard are fuel injectors to clean/replace
bobby m replied to aperseghin's topic in MJ Tech: Modification and Repairs
not hard at all,relieve the fuel pressure , unplug the wires from each injecter, unbolt the fuel rail and gently pry up, once it's up you can just pull out the injecters by hand, then revrse order to get it back together. -
Do you prefer a body colored tailgate handle on your MJ?
bobby m replied to fiatslug87's topic in The Pub
It must be black. -
welcome to the club
nice find
thank you
ex. color-tan in. cololr- tan ax15 4.0 with 314000 miles build date- illegible daily driver in fort smith AR base model truck, 2x4 no factory options current owner- bobby meredith
My front fender wells have rotted and are falling out in pieces, does anybody know where to get aftermarket replacements? any help would be appercated.
cool pics your lucky to live there.
Concrete pumper/fleet mech. in fort smith AR
Making your tail lights stand out from the crowd
bobby m replied to MJ is dead's topic in MJ Tech: DIY Projects and Write-Ups
thanks for idea. somthing else i need to do. -
thanks for all the info, it will help a bunch.
Ok, thanks guys. Iwill start searching for another donor.
I do have a donor, but it has an auto trans in it. I was thinking of staying with the ax15. It's my understanding that you just have to swap the output shaft in order for it to work, or is that wrong?
I'm a newbie so please bare with me. I am going to turn an 1989 mj from 2wd into 4wd. ithink i have figured out what tcase i need, but don't know how to identify one from another. any help would be appreciated.
