Muncher
Everything posted by Muncher
  1. Alright ill do that. Any tips of what to look for what a bad socket would look like
  2. Finished insulation today and put most of my interior back together. Only broke a couple of things !
  3. I actually did give the engine a little bath a couple of days ago. I'll have to try to clean the connection tommrow
  4. So I cleaned my ground for my gauges like someone said to do to try to fix them not working. Once I did that and started it they all moved a little bit but still only the rpm gauge worked. What else should I try?
  5. Muncher
    Halloween
    Thanks !
  6. Is the latch bolted or will I have to drill it out
  7. Muncher
    Halloween
    Almost halloween! But for some reason my home depot has Christmas stuff out already. But anyways I remember seeing something about a comanche commercial where it had cat eye lookin lights does anyone have that video?
  8. So my driver side door won't lock or unlock from outside but wkll lock inside. But even still the button is super hard to press down and then you have to grab the cable through the door to actually unlock it. What needs to be replaced?
  9. C101 should be good because I cleaned it out good as something to see if it would make the truck run before it did
  10. Its blue i think? Its an 87 I'm going to check the ground for the cluster it self in the morning
  11. Rip
  12. Thank you I found a good article on there about changing the blower motor and fan which i will try and see if its the problem. Even if its not seems like a good thing to do anyways
  13. I sprayed in the cowl area towards the passenger side where the metal covers over it. Didnt take anything out cause there was nothing on that side
  14. Also someone said my ac fan is probaly broken because of the loud noise it makes when it turns on. How do I access it and where could I get a new one?
  15. Alright thanks. Where can I find cruiser tips?
  16. So I cleaned out my cowl today and had to evict some mice from in there. When I cleaned it out I pressure washed it and prayed towards the passanger side. This made water come out onto the floor of the truck.is this just because of the pressure washer or w leak I need to fix?
  17. Alright. Is that the ground for all the gauges? Also what gauge wire would you recommend I'm not the best with wire
  18. Where are the grounds for the gauges ?
  19. Ok so I didnt really run it long but when I got my truck back today I tried the ac for like a minute and it sounded like it was screaming and also a train whistle at the same time. Anyone know what could cause this?
