Everything posted by 88towmanche
PO swore it was a factory MJ 44 - said it took him months to find but you never know There was a piece of duct tape on the left tube - nothing legible on it. The brake line on top of the left tube looks identical to the 35 on my other truck (blurry pic) Can't find any evidence of cut off perch or sloppy welds on the ones on there - if it was modified they did a good job. Should have it out today/tomorrow and get a closer look at everything
What is the order of disassembly - does it matter... Disconnected the e brake cables since they were easy and right there. Broke all the ubolts loose and working on the lower shackle bolts. Once everything is unstuck - figure: Disconnect and cap brake lines. Drop the drive shaft. Unbolt lower shocks Remove ubolts so axle is free of the leafs and resting on jack/pallet jack Unbolt shackles let the leaf drop and pull axle out.
Yep - that's the donor truck and agree AAL for sure, that spring pack will stay with the donor. Going to swap the axels and snag the tail lights, rear flares, tailgate, bucket seats and few other odds and ends out of the donor and then send it on to glory - will offer what's left up cheap on CL or FB (wifey tired of sanford & son yard)
That's what the PO says - looks like one to me, but I'm comparing to pics off the web - don't have one to directly compare. Says it has a locker in it as well....guess we'll find out. Truck is pretty hacked up - think it was a wheeler, exhaust is routed up through the bed and the front fenders are cut.
Finally going to carve out time to swap axles with the '86 4 cyl parts truck. The '88 currently has stock 30/35 with 3.07 gears The '86 has 30/44 with 4.10 gears Even with the complete donor truck expect there will be issues... Figure that neither drive shaft is going to work...maybe the one out of the '86? Both trucks are 4x4 but with different motor/trans in the '86 not sure it will work. Prepared to have a new one made. Brakes? The original brakes in the '88 are intact and like to keep it that way - is the D44 different enough that have to make any radical changes? Longer lines maybe? Will definitely replacing the shoes/cylinders/springs in the rear drums but hoping everything else lines up. New shocks going in the rear - have airbag helper that will probably go in as well to help with squat when towing - unless there is some other suggestion for helping the old leafs which do not intend to replace or AAL at this time. What else? - the front D30 should just be a straight swap - was there any major difference between 86 & 88 on the front axle? Any of you guys done this or have tips send em my way
A/C Receiver Drier to Expansion Valve hose
88towmanche replied to ktmall07's topic in MJ Tech: Modification and Repairs
Have one made at a local hose & fitting shop - we've done it many times for marine applications (boats are all funky and one-off) Not that much $$ -
The factory screws pictured look like hi-lo pan head screws - probably #8 X 1" or so - stainless a good idea.
Damn! I guess bought mine a couple years ago - no idea they were gone, that sucks.
We always use the heavy duty attached lid totes - like from Grainger. Stackable in the garage, easy to swap out from truck to truck - each loaded for specific use: Chains, collapsible shovel, salt for winter driving Tarps, tiedowns, bungies Hitches, pigtails for towing tools, jumper pack, jump cables. biggest challenge is keeping them from sliding around - running a single cable down one side of the bed attached to the tie downs we have short leashes the use caribiners to clip to the cable.
Rear Shocks recommendation
88towmanche replied to Whitaker717's topic in MJ Tech: Modification and Repairs
Probably would - I was a bit concerned about that so figured that when I put the 2" puck & shackle lift on the truck I needed to add a 2" spacer to the airbags. I'm not out flexing the truck on trails so don't think will be an issue. -
Airbag kit: Amazon.com: Air Lift 59503 Ride Control Rear Air Spring Kit, Black : Automotive Should help squat issue without affecting ride -
90 Comanche 4.0 fuel smell
88towmanche replied to comanche32's topic in MJ Tech: Modification and Repairs
Man I hope that is not the issue with mine (sounds like a hassle) - my truck sat for like a decade before I bought it, PO would fire it up every 3 or 4 months but never used it or put much gas in it so my theory is the top of the gasket just dried out - you can see where it's leaking if you fill up all the way - at least that's what I thought....now going to take a closer look at those hard lines. -
If you're smelling fuel with the truck sitting static overnight probably not manifold related. Tank gasket leaking is my bet - mine leaks at the top 1/3 of the gasket - if I fill the tank it stinks like hell until it gets down to 3/4 tank. Been like that since day 1 - got the replacement gasket but every time I get under there to swap it out I find something else and get sidetracked - last time discovered a frayed ebrake cable and that turned into a bigger project than anticipated. -
Lot of concerns pulling 5,000 lbs with a 30 yr old small truck. Tongue weight alone is going to be 500-750 lbs - that's gonna make the rig squat - mine does with 250 lbs on the old springs. I bought a helper air bag set up off amazon but am now looking at new metric ton springs when I swap out the axles to improve gear ratio - 3.07 gearing is unusable for towing - and this is just to tow around a 3,000 lb boat. Weight distribution hitch set up going to add another 100 lbs to the squat.... Don't know much about electric brakes (usually tow boats & they are surge if equipped) - so not sure how you get that all wired up on an old jeep, i have it on my Sierra but that was all factory and worked great on a travel trailer I drug around with the family for years but there is no way I would have ever tried dragging that thing with the Comanche and it weighed in at 4800 - but not the same as pulling a boat. I rented a uhaul tandem utility trailer and hauled a cord of firewood a couple weeks ago - figure total weight was around 2500 and it handled it fine, but it's working hard and you don't want to get into a hard braking situation - 5000 just doesn't seem doable on a regular basis without substantial mods.
3.5" Lift with 31" Tires?
88towmanche replied to DesertComanche86's topic in MJ Tech: Modification and Repairs
89 LB 4X4 w/column shifter....
88towmanche replied to 88towmanche's topic in MJ Tech: Modification and Repairs
Nice looking rig - the one on Craigslist up here is long gone, I missed how old that posting was. -
This popped up on Seattle CL - 1989 Jeep Comanche SUV - cars & trucks - by dealer - vehicle... (craigslist.org) Don't think I have seen one with column shift - gonna see what these guys will take on a cash offer - this combo can't be that common...
