BrownBetty85
BrownBetty85's Achievements
  1. I'm in the San Antonio area and will have a set of axles w 3.08's soon if interested
  2. Good luck with that I'm doing pretty much the same but motor and all so I have entire wire harness to do also but have done before the donor XJ was the receiver 7 years ago for 93 into an 85. Oh this addiction can make you a gluten for punishment!!
  3. Good luck with that I'm doing pretty much the same but motor and all so I have entire wire harness to do also but have done before the donor XJ was the receiver 7 years ago for 93 into an 85. Oh this addiction can make you a gluten for punishment!!
  4. What year tail lights are you using from the Camry? Thanks
  5. The FF at the end is a double sealed bearing if that helps at all
  6. Love the tech lesson guys. Great job and information
  7. One needs regluing as it is. Wast to throughly clean and repaint the silver backing. Just trying to get the best out of what I have to work with. Really glad I joined this club. Lots of great info and friendly help. The kind of stuff that makes the world go around!!
  8. Thanks Pete I will give that a shot. One already worked most of its self loose so that shouldn't be a prob but REALLY don't want to break the lense just paid $140 for them!
  9. Does anyone know how to separate tail light lenses from housings? Thanks
  10. Most of those bearings are 204ff. If you have no luck I have one of those brackets and pulley available will let go very cheap( make offer) plus freight. I'm near San Antonio, Tx
