Gatorgirl
Everything posted by Gatorgirl
  1. Yes, this is a brand new tank. Tank is 16 1/2 W 29 5/8 long and about 12 to 13 deep.
  2. No the old tank is gone the new one is J670105 replacement fuel tank from Carparts.com
  3. I need some help! I have a1987 MJ Sportruck 4 or 5 years ago the gas tank and all of its contents rusted out. It was replaced be a fuel cell in my tool box in the bed and an electric inline fuel pump under the truck. Last year I found a sending unit and tank that runs in the we installed in bed to see if would run and it did. We then tried to mount it under truck and it was too wide and is to close to drive shaft. So I ordered new tank thinking it was wrong size got same size tank. All of the tanks on most websites are same ones. I don't know why we can't get it to fit properly.its a swd 2wd 4cy. Any help would be appreciated.
  4. It's Located under Diy projects and tech writeups
  5. I would love to have it, but I'm in Florida long way off!
  6. They are j-bolts and you can get them at gastanks.com
  7. Thanks for the pic, are the part number embossed on the unit so you can also verify that way to.
  8. Hey guys. Does anyone happen to have any pics of a sending unit that fits 87 2.5. I got one or so I was told. Just want to make sure before buying a new tank which I also need. Thanks
  9. I'm having one of those dumb moments but what is the PDC?
  10. Problem I can't find any that's why I trying to get XJ brackets, but haven't been able to find any of those either so far.
  11. I'm real short and the bench is a little to wide for real comfort especially with a 4 speed. I think it might make it easier with buckets!
  12. I have some bench seat brackets and on this site there are some mods to fit both in a MJ.
  13. I'm looking for a set XJ sliders and or brackets to put buckets in my 87 MJ. Any help would be appreciated.
  14. I've sent you a pm, but not getting any response? Are you still selling the shirts?
  15. I would like to get a shirt. XL in black print front of truck on front and back on back with the hockey sticks.
  16. Hey, I'm the original owner of this MJ. I've always had someone doing the work on the MJ. I finally retired and decided to try my hand at doing it myself. My biggest problem seems to be rough idle. I'm in the process of doing your tips. Done some,but not all of the grounds. Now I'm cleaning C101 connector, it was so clogged up you couldn't see anything inside. I'm going to soak each side connector in some brake cleaner for a couple hours to see if that will get the rest of it out. I would like to thank you for all these tips. You and all on cc are very informative. Probably will have a bunch of questions.
  17. Thanks for the responses to my question. I saw what appears to be test sockets in the engine bay they have yellow caps on them. Just asking I'm new to working on my own MJ.
  18. Does anyone know if there is obd reader for a 1987 MJ 2.5.
  19. The Amazon link for the headlight harness says it doesn't fit 87?
  20. If a for sale topic is locked how do respond to the ad?
  21. I sure like what you did with your Mj. I have 87 2wd 4 cy. 2.5 4 spd. Sportuck mine is beige. I'm the original owner. My gas tank fuel pump and sender all rusted out! Couldn't find a sender anywhere so went with a fuel cell and external fuel pump. I would like to put it back original, but don't know where to get a sender. Is your fuel system still original? Any idea where I can find a used sender, have checked all junk yards with no luck!
