ahmincha
Everything posted by ahmincha
  1. I did the bypass and also checked codes no codes and the bypass same results
  2. Merry Christmas Yes i did have a gauge hooked up. 30lbs psi with vacuum hooked uo 40 with out. it will sit and idle for a few minutes then guage will show loss of pressure and it starts to stumble then stall at 0. then when you immediately try to start it it starts right up. fuel pump was replaced 1 yr ago I did make a short video but its still to large to post
  3. Hello everyone as the title says I have a 1992 4.0 automatic. It has no codes in it when you start it up it'll run then it starts to stutter as the fuel pressure drops and then stalls at that point it'll mediately start up every time. It has the new idle air control and throttle positioning sensor that are less than a year old. And also rebuilt distributor any help would be appreciated
  4. ahmincha
    Sender unit
    I an looking for a sender unit for a 92 4.0 small tank. it doesn't have to be good my plan is to have it rebuilt and shelf it for future use
  5. ahmincha
    Seat cover
    I hope I worded this correctly what I am looking for is the upholstery for bench seat in tan. not a seat cover. If someone is willing to remove all thoses hog rings and ship. Also looking for the comanche specific interior trims in tan
  6. What type of solder and flux did you use. Looks great
  7. about ready for a ride
  8. few more pics
  9. Thank you wheelsaz08
  10. Paint is done going back together
  11. Thanks dragordie
  12. Also i believe coopers are made in USA
  13. Thanks buxmj I'll take more pics as I put her back together
  14. Dash in
  15. All chassis saved (por 15) Like material
  16. I have 1 no logo in Ohio
  17. I have 1 no logo in Ohio
  18. I have 1 no logo in Ohio
  19. ahmincha
    Seat cover
    Looking for a oem tan bench seat cover
  20. Its not the right one ecm has 3 separate plugs sorry
  21. I will send you that tomorrow
  22. Well stroker I picked it up today from Akron also scored some Firestone destination at that were like brand new on same truck with aluminum rims . Thanks again
  23. I have a complete harness with ecm I just can not remember what year it was from. Do you know any way for me to ck
  24. Thanks Steven
  25. Finally the color
