ahmincha
Everything posted by ahmincha
  1. not sure about that atleast they don't bite i personally don't like any of them crawly things
  2. Yeah i plan to i"m going to use leaf blower respirator eye protection and tyvek suit blow it out rinse it all out. The stuff i used is water soluble so hopefully that should do it. Then on to repair
  3. Could it not be bled correctly. Is there any play in the clutch pedal
  4. Well to late i fogged before i posted everythings coming out of the truck anyway i had to do it them things make me crazy i would not of drove the truck
  5. The good news 2 little holes in floor board
  6. Hay everyone has anyone ever had coach roaches under there carpet. I just bought comanche from Kentucky started pulling the carpet and it was loaded with roaches. Just wondering never had this problem before so i closed the doors and put one of them fogging cans in it if been itching all day
  7. Thanks Pete M Yeah i want a later year just don't no how late i can go on the trans and tc
  8. Thanks eagle have not taken off the cover to confirm but i have window sticker from the 86 and under optional equip it says axle ratio 410/1. Here' s hoping
  9. Thanks dasbulliwagen i believe my 86 has 410s. When looking for ax15 and transfercase what year cherokee should i be looking for for the easiest swap.I think i read that i want to look for them from a 91 92 comanche because of the pilot bearing but need to know years for cherokee
  10. do y still need a bench I'm in cleveland ohio
  11. Thanks for the reply Rymanrph. Nobody knows about the axles
  12. Hi everyone, Just picked up a 92 2wd 4.0 ax15 mj. Going to convert it to 4wd my ? is will the axles swap from my 86 2.5 4 spd and if so due i have to change yokes or uca lca or is it a strait forward bolt in . Also can i get the axles in and drive the truck without changing trans and transfer case at this time (in other words no front drive shaft hooked up) until i find the trans and transfer case. As soon as i get started i will list a bunch of stuff for sale in classifieds so if you need something keep a look out
  13. am i right that i need a trans from a 91 or 92 and if thats the case do i also need the tc from same year
  14. the 92 is a 4.0 5 speed basic use is to plow my driveway and run around locally.
  15. Hi everyone, Couple ?s going to convert to 4wd what i need to no is will front and rear diff and drive shafts out of a 86 2.5 comanche work in the 92. I also have access to diffs and drive shafts out of a 90 with a 4.0 in it . next ? will the trans and transfer case out of the 90 work in the 92 both are complete trucks. Any pros or cons to either one thanks in advance. I will take pics and post them when i start
  16. Well i found out 86 2.5 have positive pressure egr valves to ck them they must be on vehical unless you have a special tool. you need to bring engine up to 2000 rpms and see if egr valve moves. As for the blue vacuum line it is a vent the red is the vacuum supply
  17. Hi everyone I have a 86 comanche 2.5 i redid all vacuum lines and decided to ck egr valve. So i hooked up a mighty vac to it and there was no change so i removed the egr valve hooked up again and it did not move or allow the gauge to build vacuum. So i bought a new one hooked it up to the mighty vac off truck same as old one no movement won't build vac am i missing something shouldn't apply a vacuum gauge to the egr make it move. Also its 4 wheel drive there is a blue vacuum line that goes underneath does it get hooked uo in engine compartment and where thanks in advance
  18. thanks for the reply i want to use renix and original wiring and ignition this is just a truck i use to plow my drive and run around in don't want to get to crazy on this one I'm in the middle of converting my f450 from gas to diesel need a easy one next so I'm taking it that my old accessories will work on the 95
  19. just wondering does any one know if a 2.5 out of a 95 wrangler will fit in a 86 comanche
