Brook Mueller
    Boise Idaho
815 profile views
Brook Mueller's Achievements
  1. My Sportruck is for sale, $12,000. I put some updated info in the for sale forum. I forgot to mention that last winter it got a new windshield and 97-01 cherokee style rubber windshield molding professionally installed.
  2. Its not terrible, just feels a little loose in the middle, and has a very little bump steer - but even a little bothers me as its my daily driver. Driving 20,000 miles a year with it... when I get on Canadian back roads full of potholes it goes all over the place. I am planning to put in a high ratio steering box, either a XJ box or a newer PSC box as well as the Curry link steering and think both of those should help. But as for geometry I think it needs offset ball joints and a different pitman arm.
  3. Its taken me for ever to get around to getting back on here, but here is the most recent update; the big change is the Napier Precision Products fender flares! which really look good on the truck. I have been driving it for 2 years now as my daily driver with no intention of stopping! Life got busy, I got married, I move several times a year for work, so other than the flares nothing much has happened with it aside from putting 32,000 miles on it. . I finally have some time this week and the goal is to try to finally finish the overhead console /computer and visors, get a new windshield, and side mirrors on (one is not heated, while the other is pitted and rusting badly on the mirror surface), as well as update the steering box to a high ratio box from a ZJ. After 6 1800+ mile road trips I am getting tired of the steering.
  4. Thanks! sorry to never answer the question about the rear window MJ Junckie, I couldn't get logged in for the last 4 months.. just figured it out this morning. Yes it is a stock MJ sliding rear window.
  5. Thanks! I am planning to put some flares on it. I work in Canada in summer and up there you are supposed to have mud flaps too.. so for the sake of hopefully not getting pulled over I am going to add some flares. I actually have gotten a lot of rock chips already too. I had fit the original Comanche ones on to the new style front fenders before I painted it, but then I used a black rhino bed liner spray on them and they bubbled really bad even with plastic adhesion promoter and the proper prep work.. I had to throw them out:( plus they looked so glossy they just looked terrible. So I am trying to decide now between more originals from the junk yard, or bushwackers, or flat bushwackers.. what do you think? I am kind of leaning toward the flat ones as I don't see a ton on Comanches with them.
  6. Final Assembly; I put the whole thing back together and worked the bugs out in three days and took it on a 1700 mile road trip to Wisconsin.. I only live in Idaho in winter so I was in a real crunch for time to get back to WI. I actually went a week over as I only had 3 weeks for the paint when I started, I was supposed to leave for WI the 16th of April but didn't end up ready to go till the 22nd. . Pics of the Hanson rear Bumper and JCR front... I really really really wish I had got one I could mount a winch too.. duh this is my first jeep :( now I need a new bumper.. Loaded up and heading through Wyoming!
  7. back in the yard we used a raptor kit bed liner tinted the same Commando Green Bed back on the frame and bed liner done
  8. Paint job work, I did the whole job in 4 weeks. Did all the body work and primer in my garage then took it to the shop my buddy works at to have it painted in the booth, single stage Comando Green with Limco Supreme paint. Its relatively cheap paint, the whole job cost me about 1500 mostly sandpaper and primer. I welded up several holes in the side of the bed and tailgate, removed the metal tailgate linkages and put some newer style cables on it as well. I did the hood, grill, tailgate, bed and fenders first. Then did the cab and doors separate... not enough room to work on it all at once.
  9. Disk brake conversion done, new shock mounts, new ubolts and plates over the rear springs, and an extra short leaf I cut and put in cause the back was squatting a little. Before putting it back together I also ran new rear brake lines and a rear proportioning valve and stainless line to the axle. Also new exhaust and cat is visible that I had put on a couple months earlier.
  10. I eventually changed all the interior parts to black, took out the seats and shampooed them several times, put in new carpet and floor mats, and changed the switches in the driver door to a 2 door model from parts I bought on ebay. (no need for rear window switches on a 2 door) I also fixed loads of wiring issues with the old harness under the floor, and shortened the parking brake cable so it didn't have a big loop in it. I wish I had pictures of all of it, but here is the couple I found before and after. I also used hushmat on the whole cab.
  11. First weekend driving it.. I decided I would spray paint the hood and grill so I sanded all the loose pealing old paint off, I'm a newbe at bodywork at this point. It stayed like this for 3 months actually without getting much done to it except for the maintenance it needed to keep driving. To get it to this point I worked on it for a month, First thing I got was the new 16" alloy rims and Toyo tires.. they are close to a 33 x 11.5 ( ill check the size again later) I went through tons of clearance issues with the suspension arms, I ended up putting Rough Country long arms on it, with RE 5.5 springs in the front. I welded new spring mounts on the back axle as the previous ones had been done to wide. In the process of grinding the old ones off the fuel pump lit on fire due to sparks.. so luckily the truck was spared from the flames and it also got a new fuel pump. (my tank and pump is from a 98 Dakota to have the correct matching ohms for the 97 instrument cluster). The gas gauge still didn't work at this point which would take a ton of trouble shooting latter on.. and an eventual new Dorman re manufactured cluster to the tune of $600 Ouch! I payed a local shop to re-gear both axles the Dana 35 front and 8.25 to 4.56. I hoped in and drove it to Portland the day after I got it on the road with the new gears... It pulled terribly and the first modification it got when I got back to Boise was a steering box brace. It ran good for the total of 900 mile trip until I was about 3 miles from home coming back into Boise and the alternator died. I bought a new battery that night to get it home. It took me about 3 weeks to figure out it was the alternator, I took it and had it bench tested twice and it tested good both times.. but the thing was intermittent and I got stuck one more time in the boonies a couple weeks later when it quit charging again.
  12. figured out the pictures:) I hope these are posting, here is a few more of the beginning
  13. Thanks! i am new to this and having a terrible time getting pictures on here>>> sorry. I think i have tried almost everything imaginable......
