Everything posted by RustInMyEye
My 88 Comanche Restoration and Modification
RustInMyEye replied to RustInMyEye's topic in Member Projects: Your Comanches
50 degree day Seam sealed the cab floor. I might make this thing a submarine instead. Raptor Lined the floors. Everyone could and should do this. can't wait to do the other truck areas. (rockers and bed) So much change with so little effort isn't something i'm used to Better day for pictures -
I put the doors on to help keep snow out. My drivers window will only go half way up. Tossed the nose/grill on to keep my tarps from ripping. Anyway. I could be putting the interior back together but i wasted a warm weather window re-roofing the garage, really... who needs a roof. So I have yet to raptor line the floors. oh, I bought a C.R. Laurence rear window on amazon. It actually looks really good. Huge rear double slider. So here's this update of a very blue looking caged Comanche waiting patiently -
I know very well the point. My RV comment was mostly to add affect to my distaste of the walk through Idea.
If you want an RV buy an RV... There are a thousand other vehicles that would be a better start for this. I basically hate your idea of cutting the cab of the Comanche to make it a walk through. If anything, the last posted camper is the way to go. You could sell your bed for probably a grand.
Tried to paint the cab, cage, and engine bay. Primer went on well the top coat didn't. The combination of poor thinning, ignorance of paint spraying in general, and a 35 buck amazon spray gun didn't amount to a great finish. The top coat would barely spray, I don't know how the cage ended up as blue as it did given the circumstances. -
Do you really need the step pads? I would just throw down some rattle can bed liner on them, it would be way better grip then the smooth plastic.rubber step pad.
I block sanded the blue to make it look presentable. I'm hoping the sprayed topcoat will take care of the remaining small surface waves. I'm thinking of color matching the cage. Painting it blue. I need your opinion. The thought was that it would trick the eye and blend in. -
The chassis is black. Ended up being windy so there are a lot of dust specs I figured it would be best to throw some top coat on the roof, behind to door cab section, and A-Pilar so I can weld the cage on and then spray the rest of the truck with some quality control. The top coat ran horribly, but it helps me move forward. -
I keep working and there keeps being more work. I welded steering box spacer stand offs onto the inner frame plating. I wanted to make each of the cage tubes wrap the slider like the first picture. I didn't do math, cut twice and measured once, so i attached these to support the overhanging tube. Finished up the rear bumper with some tubes that wrap the corner, these wrap nice and tight with the bed cut a 3/4 inch below the lower body line. Trying to make it stay comanche'esk when you look at it. The open tubes have been capped, but I didn't take a picture. The plan is to paint next weekend. Tuesday, Wednesday and Thursday are to bring heavy rain. So I'm betting on it being another beautiful weekend next weekend after the passing storm. All I need is the Por15 on and then i can rest easy. Priming and top coating whenever. As i look at these pictures everything looks so rusty, glad to know the best Paint Over Rust paint is about to be slapped on. The blasters did a poor job when you think about how they seemed to miss the hard to reach spot and get all the easy spots. I have to get all the primer I sprayed throughout the build off the bottom of the frame rails. i -
Saturday brought Floor supports The last piece of the floor puzzle, at the end of the tunnel Inner y thing. The two tubes going up and slightly off center, but I don't care. These are welded in place solid. The truck will be painted and then the cage put on and welded in, then the cage points will get painted. I didn't make it a true x cause this isn't going to be a race car, and that space will make fore some needed inside storage. Thing I'm going to make mesh bags, to hang right there. Sunday was rainy so I did some axle stuff. Before After I'm going to just slide right over rocks. -
1 quart of POR self etch primer and POR high build primer ordered, this will only be for areas getting top coated, but I will be trying to stretch it as far as I can. 1lbs POR epoxy putty ordered This rig will be a real testament to POR products when its done. -
Its called dustless blasting, which is pressure washing with small amount of crushed glass bead added (basically sand). Used about 600lbs of it. The paint line up is coming together. 1. POR Marine Clean - Misted with spray bottle 2. POR Metal Ready - Misted with spray bottle 3. POR 15 Rust preventor - Brushed on 4. Bondo or epoxy putty - Spread like peanut butter (Yet to buy) 5. Seam Seal- Caulk gunned 6. POR High Build Primer (most likely) - Sprayed (Yet to buy) 7. POR 2K Urathane Top Coat - Sprayed 8. Raptor Liner in the bed and Cab floor - Sprayed 9. Bumpers, cage, and rockers will get spray paint black -
Today was crappy weather but I redid the doors in the garage. Nothings comes out as good as I want it too these days, but no way they're going to rub the rocker panels now. Cut like a 1/2 inch off the bottoms. I started out with a better piece of metal to cap the bottom, but it takes soo F-ing long if you want to shape it perfectly. A patients I have lost at this point in the build. -
blasted. Before After Draining the frame The beds cooked, nothing good lies under that bondo, but ill probably chip off what remains , por15 underneath, bondo it up again, and then top coat it. Not really looking to spend a billion hours on it. Does anyone sell replacement bed sides anymore? I was in the process of cutting off the terribly rusted gas filler when the blasters arrived. -
Alexia's 1987 To 1997 Comanche
RustInMyEye replied to Alexia's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Alexia!!! where can I find that Steering Shaft bushing!?!?!?!?!!?!?!? Its looks brand new, do you have any recollection of where you got it? -
Patching up the rusty firewall. this will also fill the gap left when using the 97+ Hvac unit used rivets here cause the thin metal, this covers some holes made when removing <97 dash brackets. here's an example of what that covers also cut away the old rear bottom cab metal. wile its still a uni-body. the cage and frame are the protection. the cabs extra bracing is just useless now. -
this is whats going behind the seats in the main x spider thingy i mentioned -
Its gonna be a cozy in the cab. If I wasn't 6'2" everything would be a lot easier. The seats are in the same location as stock, but the way my cage was designed its going to prevent a more relaxed, laid back driving. Fine for anything offroad, not great for any long drives. But I really won't be able to tell until its finished at this point. seats mounted dash tossed in to check space middle tube of the main hoop spider thingy. The V thats going to extend from the middle of this tube to the corners will likely be the most limiting for seat adjustability and comfort. Here is some strapping I did between the outer and inner frame stiffeners in the front. I didn't like the weak point left between the two. -
So, I put a seat in the jeep. They are quite large, or rather, I never realized how tight the cab was. I'm hoping the center counsel lid will be able to open. -
Got all the gussets done and tossed it on to make sure it all still fit. Bought this procar sportsman seats. I'm not hating the quality. Mounting these will also be way easier then stock seats. -
Rear bed mount. Some gusseting. A few of the notches weren't as clean as I would like. The gaps were filled with a piece metal and then welded over. The gussets make me feel better about not scrapping the whole tube and starting over. Theirs definitely a learning curve to cage building. the back half is way better then the front as i built front to back. -
Hidden style hitch in the welded on slab bumper. Support piece for 6th cage points. Front couple bed mounts. On the rearmost mounts I'm using the bed's stock bed side bolt, that hangs down from the bed, so Ill measure and those will be the next thing that get added when the bed is popped off. The bed mount tabs I welded on will get some steel plates bolted to it and weld those straight to the bed. -
I have been working I swear. The only real welding tasks left include a rust hole on the firewall and the door sill areas behind the front fenders and doors. So when i pull off the cage, doors, and fenders I can do that. and the bed mount tabs and some other various tabs for fuel lines and gas tank mounting and break lines and e brakes Then its like sandblast and paint time. Bottom of doors where trimmed. F'ed up and need to be modded but done kinda. They are too close and rub in one spot on each side. Inner floor the mini boat side floors Front outer floor areas, rocker panel/slider Rear bumper acquired and I cut a hole for a reciever -
Imgur annoys me
