ownedueasy
Everything posted by ownedueasy
It done it a little bit about 4 months ago then stopped.. now it's going it every time I drive the truck.. sometimes it goes crazy sometimes it just doesn't work. The link is what it's doing. Anybody know what's causing this and how easy the fix is
Looking for a 48.5" or 49" driveshaft (some what local illinois) I don't have cash but I do have a 2wd ax5 to trade for it (cracked bellhousing), u joint went out and It grenaded, it has a new rear seal in it. I already have a TH350 yoke for it
I know this is probably a long shot. But does anybody have a spare shifter linkage piece I may have for the price of shipping please It is this piece here http://imgur.com/jKr2wuT
Ok so I was at a local JY, and they had a international scout 800A, I was wondering if the d44 out of the back would work on my mj? I know spring perches, and gears, but is it narrower than my d35 or wider? I can't get back to the yj for a few weeks or I would measure it myself, everything was set up like an mj, rear was centered diff, and front was drivers side diff. And also what about the front is it also a d44?
Ok I'm in the middle of converting my 92 shortbed 2.5 ax5 to 4x4. Since the stock drive shaft won't work. Will a drive shaft from an mj with a 4.0 shortbed work (length wise) I already have the correct slip yoke.
Ok, well thank you guys. One less thing I've gotta get
My front end is gona be on 3" lift springs, 2" coil spacers, and 33s. Just looking for parts my stepdad told me to
Ok so somewhere I read that a stock grand cherokee drop pitmann arm will work as a 4 inch drop arm on an mj? Please give me more details on this
it won't let me register it says "Sorry, registration is currently disabled."
91, sport truck 2.5, 4 speed, 2wd. only dash speakers, bench seat. 2 speed windshield wipers(fast and faster) steel wheels, rear slider window. drivers side mirror only. dummy light instrument cluster.chrome exterior trim,
I'm not sure, I was just searching row52.com and found it
Can I get some injector help please? I Wana upgrade injectors but not sure what ones will fit. It's a 94 yj motor in my 92 mj.
VIN 1J7FT26P5ML549924 Model Year 1991 Make Jeep Model Comanche Engine Type 3 Li I4 Body Pickup Regular Cab Style Various Fuel Gas Safety ACTIVE BELTS Driveline RWD Transmission MPG 0 miles/gallon Wheelsize R15 in. Wheelbase 113 to 120 in. Overall Width 72 in. Overall Length 179 to 194 in. Overall Height 64 in. Vehicle Weight 0 Manufactured In TOLEDO ASSEMBLY #1: TOLEDO, OH PICK-n-PULL Kansas City (12th St.) Kansas City, Kansas 66105
VIN 1J7FT26S2NL194118 Model Year 1992 Make Jeep Model Comanche Engine Type 4 Li I6 Body Pickup Regular Cab Style Various Fuel Gas Safety ACTIVE BELTS Driveline RWD Transmission MPG Various miles/gallon Wheelsize R15 in. Wheelbase 113 to 120 in. Overall Width 72 in. Overall Length 179 to 194 in. Overall Height 65 in. Vehicle Weight 0 Manufactured In TOLEDO ASSEMBLY #1: TOLEDO, OH PICK-n-PULL Springfield Springfield, Missouri 65803
VIN 1J7FT26S3NL166330 Model Year 1992 Make Jeep Model Comanche Engine Type 4 Li I6 Body Pickup Regular Cab Style Various Fuel Gas Safety ACTIVE BELTS Driveline RWD Transmission MPG Various miles/gallon Wheelsize R15 in. Wheelbase 113 to 120 in. Overall Width 72 in. Overall Length 179 to 194 in. Overall Height 65 in. Vehicle Weight 0 Manufactured In TOLEDO ASSEMBLY #1: TOLEDO, OH Ace Pick A Part Jacksonville, Florida 32218
VIN 1J7FJ36L6LL167022 WMI 1J7 VDS FJ36L6 VIS 6LL167022 Checksum 6 VIN 1J7FJ36L6LL167022 Model Year 1990 Make Jeep Model Comanche Engine Type 4 Li I6 Body Pickup Regular Cab Style Various Fuel Gas Safety ACTIVE BELTS Driveline 4WD Transmission PICK-n-PULL San Jose North San Jose, California 95112
VIN 1J7FT36S0ML551588 Model Year 1991 Make Jeep Model Comanche Engine Type 4 Li I6 Body Pickup Regular Cab Style Various Fuel Gas Safety ACTIVE BELTS Driveline RWD Trim Was Pioneer PICK-n-PULL Arlington Arlington, Washington
slip yoke while converting to 4x4
ownedueasy replied to ownedueasy's topic in MJ Tech: Modification and Repairs
I got one today from the Junk yard from a suburban turbo 350. Got lucky and the owner gave me the carbon/aluminum drive shaft with it.. what are the chances I won't have to cut the shaft? Just put the new slip yolk on my old shaft and it'll work? Because it looks extremely close. -
Ok, while converting my 92 2.5, ax5 to 4x4 I bought a trans, tcase, from a 92 yj, after I got it in, my slip yoke from my old ax5 2wd is way too small in diameter. Any help here please on which yoke I need to find I think the tail shaft on the 4x4 is 27 or 28 I'm not 100% sure didn't have a marker to mark where i started counting
It is in, sorry about that I was trying to line it up with the front holes on the transmission. *face palm*
Yes, it's all the way forward on the holes and it's off longitudinally, I will go out later and check again but I'm almost 99% positive it's wrong
Ok I'm converting from 2wd to 4x4, it's a 2.5. And the 2wd cross member won't work the bolt holes are about 3 inches off. Will a cherokee cross member work? And if so does it matter if it came from 4.0 or 2.5? Aw4 or ax15? Or would you suggest welding a plate on mine to extend it a bit? Only welder I have is a cheap 110 Flux core wire welder
94 YJ 4 banger in a 89 MJ
ownedueasy replied to foreman1063's topic in MJ Tech: Modification and Repairs
I have done 93 yj (I believe it was 93) 2.5 into my 92 mj. Only thing that was changed were motor mounts, and intake. Other than that it was good to go
