ownedueasy
Everything posted by ownedueasy
  1. No, nothing is Bent, everything I've done to the front end is lower adjustable control arms, Springs and spacers, and adjustable track bar. The d30 housing is out of a xj. Internals are yj (couldn't find anything in 4.10) the inside of my rim is rubbing on the sway bar Mount at the axle. The links are current out of it because I'm waiting for shipping.
  2. No pictures currently, it's a 4.5" spring with 2" spacer. There's no sway bars on it right now, it's hitting on where the sway bar mounts at on the axle. It's a d30 front, with stock xj size tire size. Almost everything under the front end is adjustable. The sway bar links are being shipped right now.
  3. Ok, got tired of fighting with my MJ on getting it back together as I couldn't figure out the transfer case problems or front end problems. So I took it to a reputable 4x4 guy. He got all the problems straightened out and told me I needed a different off set because my wheels were hitting the sway bar links? I have stock tj rims on it now. The jeep is lifted roughly 5.5-6.5 in the front and spring over in the rear with taller perches. Just wondering what offset I would need to not rub at all? This is the wheels I have on it right now https://www.google.com/search?q=stock+tj+wheels&client=ms-android-att-us&source=lnms&prmd=sinv&tbm=isch&sa=X&ved=0ahUKEwiH2KimicDPAhXMPiYKHcWwAVMQ_AUICCgC&biw=360&bih=512#imgrc=RApix1gLHdJiFM%3A I think he said they're 5.5 offset?
  4. Tried swapping relays around and nothing, Scott mine don't come on what so ever. Drivers side rear when turn signal is on 2 bulbs blink, passenger side rear turn signal on only 1 bulb blinks?
  5. The ground is good, I cleaned it to bare metal. The connector under the truck was cleaned out also.
  6. No, hazards do not work they stay lit up and don't blink when engaged. I could possibly be mustaken, I will check again when I get home.
  7. Ok driving to work one day I got pulled over for no break lights which was news to me. Ever since then I parked it and haven't drove the truck. Finally getting around to fixing it and it has me 100% puzzled. All fuses are good, as so is the flasher and turn signal relays. Break switch is also good. I've tried them out of 3 different trucks known to be good. https://youtu.be/uzAWqGT9Goc That's a video of what the truck is doing.
  8. Could I get a picture of the switch please?
  9. I took the linkage off, and tried shifting it by the little bracket at the back of the tcase, and it still wouldn't move.
  10. No tires yet, the linkage on the transfercase the little piece coming out is down
  11. Track bar is installed already, axle is corrected under the truck. But I still count make a turn with it. I also put adjustable loweres on my truck. And eagle would I need a pitman arm with that much lift? I'm using a xj bracket and shifter/linkage.
  12. ok was doing a 4x4 swap/lift(5ish-6inches) at the same time on my 92 mj, and after the front end is under it i don't have all my steering radius i use to have for some reason. all my steering components are stock 2wd. was wondering what pitman arm i needed to fix this problem? and my trasnfercae came out of a yj, the speedo plugin isnt the same, and the transfercase won't shift, ive pried on the linkage(at the back) beat on it wiggled it and it won't move? any help is appreciated!!!!!!!!!!
  13. It's still clocked for a yj, does that make any difference? And is it possible that that would be a 242 linkage?
  14. This is at full turn, it's the same amount both ways http://imgur.com/9G67Iu8 Here's the tcase linkage. http://imgur.com/V3rR6nj
  15. I would get pictures but it's stuffed up in the truck already, I will do my best for pictures when I get back to where the truck is. The steering is roughly the same amount in both directions, which is about a 15 degree angle from the body the steering wheel isn't centered either. Lower adjustable control arms, adjustable trac bar, and currently no sway bar links in it, I plan on buying adjustable ones with disconnects.
  16. My trans/tcase came from a 92 yj. My lift is made up of 3" springs and 2.5" spacer in the front and rear is just spring over. The linkage was from an xj. I have a stock 2wd crossmember also. And my steering isn't hitting on anything it just stops turning. I've drove 3 other mjs with a similar set up and the steering was so much better..
  17. Ok after getting my truck back together, I converted from 2wd to 4x4, and added roughly 6" lift. My t case shifting linkage is Hitting between the floor and the side of the transmission, and my t case output on the front is right in the shifter bracket. And I have almost no turning radius.. Is 2wd steering components different from 4x4? Do I need a drop pitman? If so will the Grandcherokee pitman be enough drop for what I need? And is a wrangler t case clocked different than mj/xj? I'm on the home stretch of my project and hitting speed bumps everywhere all help is GREATLY appreciated
  18. There's 2 antenna wires ran, it sounds to be up high about at the bend in the door.
  19. I have investigated while someone drove, it sounds like metal and plastic, maybe metal on metal muffled by plastic. And no wires that I know of they're all tight I removed interior trim and didn't see anything
  20. Ok so for the last few months I've been noticing a rattling noise coming from the passenger side door pillar by the windshield. And I can't seem to find it, the trim screws are tight, weather stripping is tight, everything seems to be tight as it should be. Half tempted for the hammer method it's driving me that nuts
  21. ownedueasy
    driveshaft
    looking to buy a driveshaft for my 92 mj short bed, 5 speed, d35, 4x4. the length is a little longer than 49 inches, but I'm looking for stock or a bit shorter like 48.5 inches(which was length of 2nd gen camaro) measured from center of u joint to center of u joint
  22. Is that 100% all I need? Checking before i head to parts yard. And the XJ steering boxes are the same correct? No different steering shaft or anything needed?
  23. Ok so my 91s manual steering box is shot. And was wondering what all would be needed to convert to power steering.. Just a power steering pump, new gear box and new belt and hoses?
  24. Ok thank you very much, will have a look at it when the snow quits
  25. No, this is in my 91 sport truck 2wd 4 banger 4 speed
