Everything posted by Finneys98xj
More picture of you for bed please
1987 Manche Full width build.
Finneys98xj replied to Finneys98xj's topic in Member Projects: Your Comanches
Ok finally found time for a little update. I got the front crossmember built and ready to install just waiting on my shackles to get here. If anyone has any questions ask away. I hoping next weekend I'll be to get the front end prepped and installed. Front cross by Joshua FInney, on Flickr front crossmeber by Joshua FInney, on Flickr Leaf perch by Joshua FInney, on Flickr Lots of tacking in place reinstalling, checking, modifying, rinse and repeat. front cross6 by Joshua FInney, on Flickr front cross5 by Joshua FInney, on Flickr front cross4 by Joshua FInney, on Flickr front cross3 by Joshua FInney, on Flickr front cross2 by Joshua FInney, on Flickr Front cross1 by Joshua FInney, on Flickr -
I have one i would sell. I don't have time to pull it but if you are near va zip code 24161 pm me.
I pressured washed it and ordered the parts I need to build the front shackle hanger.
That brings everything up to present time. If anyone has questions I'll try to answer them. -
I'm installing a fuel cell and will be running oba. I'm torn between a flatbed or a custom stepside bed. I have lots of 2x2x1/8 square tube and some flat sheet metal. -
Well I got the 2wd axle out yesterday. Stuck the leafs in to start the mock up. Got alot of mearsurements so i know what modifications are needed to the front axle. Now just need to order some YJ shackle hangers and a few pieces of metal. Leaf mock up by Joshua FInney, on Flick -
They tranny and engine mated and dropped in. 20180128_144645 by Joshua FInney, on Flickr 20180128_154251 by Joshua FInney, on Flickr 20180215_113907 by Joshua FInney, on Flickr I'm going to run and renix intake the block is a 95 with a 95 head. I went though it before dropping it in. I waiting to get a fuel cell so I can fab up fuel lines and a fuel pump. After that I'll finish putting the intake and stuff on. The axles are going to be a 78 F250 front d44 with F150 hubs to run 5 lugs, to match the 9 inch rear. I got the front housing for FREE with a machined pass side flat top knuckle. I was originally going to run a tnt truss and clayton longs arms. But after a ton of thinking and budgeting, I'm going to run leafs up front. I have a set of stock yj leafs ready to be mocked up. 20180225_161327 by Joshua FInney, on Flickr 20180225_161331 by Joshua FInney, on Flickr I have a d300 I'm going to slowly build so when the 231 fails I have a back up. I hoping to be done around thanksgiving. The end results I'm hoping for is the Mj sitting on 37's spool front and rear with 513s. -
The next day I yanked out the 4cyl. and pulled a 4.0l out of a 88 xj. 20171225_145826 by Joshua FInney, on Flickr 20171226_172122 by Joshua FInney, on Flickr 20171226_172126 by Joshua FInney, on Flickr 20171227_104959 by Joshua FInney, on Flickr 20171228_121250 by Joshua FInney, on Flickr The engine bay being prepped for the 4.0 swap. 20171227_221350 by Joshua FInney, on Flickr 20171230_170256 by Joshua FInney, on Flickr 20171230_211438 by Joshua FInney, on Flickr The donor tranny and tcase is an aw4/np231 out of a 97 xj. 20180121_143949 by Joshua FInney, on Flickr received_1547602525294655 by Joshua FInney, on Flickr -
]Ok guy here is my 87 Mj the Christmas day after the old lady gave it to me. Stock 2.5 aw4 2wd. dana 35 The plan is full widths, a 78 f150 super cab hd44 and 9 inch rear. 5.13s with 37's on hmmv wheels. That should put wms to wms in the front a 67.5 and rear at 65. 20171225_101311 by Joshua FInney, on Flickr 20171225_101317 by Joshua FInney, on Flickr 20171225_101323 by Joshua FInney, on Flickr 20171225_101331 by Joshua FInney, on Flickr 20171225_101333 by Joshua FInney, on Flickr 20171225_101333 by Joshua FInney, on Flickr 20171225_101340 by Joshua FInney, on Flickr 20171225_101343 by Joshua FInney, on Flickr 20171225_101420 by Joshua FInney, on Flickr 20171225_101423 by Joshua FInney, on Flickr 20171225_101429 by Joshua FInney, on Flickr
No I haven't done a build thread here, but I have on another site. I have lots of 4clydiner parts and 2wd parts for sell I'll post them when I get the post count to post in the for sell section. The box I in decent shape with a few dents and some surface rust where is it dented and scratched. Its a Short box. The tailgate is the worst shape of it all but there isnt any rot in the bed. I'm in Va so if anyone needs it I'll get more pics. I will start a build thread here.
My tool book bag and then a wheel barrel for parts.
I'm of course not speaking for the seller , but in the description it said it wouldn't let him post it as a good title because it was modified . I personally believe because he listed it as a 98 4 door Comanche ( which doesn't exist of course ) is the reason it's posted that way . He did post pics of the underneath this time ( not bad ) . 4 matching flares ( and door panels ) would definitely help sell that truck IMO . The rear flare is different because 97+ flares don't bolt on to the older bed. The rear door panels are different because they are custom. The rear doors aren't stock, they are custom also. I'm fully aware the flares and door panels are different . With all the other mods done to the truck ,the flares and door panels shouldn't be an issue ( custom rear door panels , bodywork done to the rear flares to make the match the front) . I'm not knocking it , just saying it would make the truck better .. I agree wasnt saying you were knocking it.The 97+ panels are plastic so the older panels were easier by a long shot to fix. As for the flare he didn't want to cut the bed in case of an accident. He was going to try 97+ two door flares but he was fine with the look. The doors are 97+ doors but if you look they have vent windows. I forgot to mention I know the guy that built the truck. He is selling it because he doesnt drive it anymore.
My jeep is killing waterpumps
Finneys98xj replied to Timmaay's topic in MJ Tech: Modification and Repairs
Make sure you are using distalled water too my 98 xj use to eat pumps up using well water than switch to distalled water and fixed it
