Scott86mj
Everything posted by Scott86mj
👍 I bought this from dirt bound off road before they went out of business but I haven’t had time to put it on yet
Finally got to drive the MJ again. Posting a few progress pics. I ended up installing super duty axles and 38's
!986 X 4X4 Originally had 2.5 with automatic, currently 1994 4.0L AW4 NP 231 Originally had D30 D35 now 1995 Isuzu D44 rear and 86 waggy d44 build date is missing I'm working on getting it back on the road very soon. Last time it was registered was 2009, I have owned it since 2005. Located in Dallas NC
Thanks, I'll try to post the progress!
I still have this Comanche 18 years later, I'm working on setting it up for mostly trail use but I will be able to drive it to the trails. I have 4.88 gears, air lockers, long arms and 36" SS Irocs with bead locks. Axles are d44 from an Isuzu rodeo and d44 from a grand wagoneer ( still on the bench). It has been off the road since 2009. Plan is to build some kind of flat bed with roll bar.
Just buy a 4x4 xj they are really cheap when wrecked. I did the swap on mine several years ago. Bought a 1994 xj 4.0 4x4 for 200 it was wrecked. Every part you need to swap it you can take off the cherokee. Let me know if you need some info. No you don't need to cut firewall. Just swap header panel.
Yeah thats about what I was thinking. Just wanted a second opinion.
I'm having to sell my 86 comanche. I bought an 2003 tj so the wife says its got to go. I'm wanting to know what to ask for it. It has an 1994 4.0l aw4 and 231j. It has a dana 44 rear with disc brakes. 5.5" rubicon express lift with 4.56 gears. I repaired the floor boards and replaced the carpet. Body is in good shape except dent in rear of bed that I banged out with a hammer. It has 33s with like new black soft 8 wheels. It has 154000 miles on engine. I will post some picks of it soon.
At auto zone and advance a new 1 is $350 and a reman is 260 minimum. I have a 1994 xj engine in my comanche. It must be a different compressor than yours was using. That is a lot of money for a truck I drive once a week. Guess thats why I haven't tried to fix it and I've had it 3 years. If you know of a cheaper place let me know. Thanks
I was going by this http://jeephorizons.com/tech/ac_recharge.html I was wanting to know if it was easier to replace the bearing or just try another compressor from the junk yard. They are only 20.00 at the pull a part. Thanks for the input.
Where is a good place to get the bilstein shocks? Thanks for the info.
Yes I have the manifold hose and gauge set from autozone.
I replaced the condensor which had a hole in it this past weekend. I tried to recharge the system and the compressor pulley would lock up and the belt would slip. Should I replace the bearing or should I get a junk yard compressor? This is in my 86 mj with all 94 parts. Thanks in advance.
I'm looking to get a better ride out of my 2003 dodge ram 2500. What shocks would you recommend? It has the hemi v8. It has skyjacker brand shocks in it now. It is pretty stiff.
USAF I was in from sept 92 to sept 96. Stationed Kelly AFB first 2 years then Kunsan Korea for a year then the last year was at Tyndall in Panama city FL. I was a cable splicer in the Comm squadron. I miss all the guys I was stationed with. I still hear from a couple of them from time to time. I was just thinking the other day I would be retiring in 4 more years. Boy would that be nice.
I do some work for the company that makes the kobalt sockets. They are made on the same lines as the craftsman and matco sockets just is stamped with different stamp.
Is it just replacing the 2 piece with a 1 peice axle from a newer dana 30? Or is there something else to do? I'm fixin to Install my 4.56s and will do this if it is no big deal. Anyone done this? Thanks
It sure sounded like a diesel. Also did you see the Ford recovery team on the door.
http://www.pirate4x4.com/tech/billavist ... index.html
My wifes wj rotors are warped again. Any suggestions to what brand rotors to get? This set was bought from advance. Factory ones warped also. Should I just have them turned or buy new ones? Thanks in advance.
