jeep_freek88
Everything posted by jeep_freek88
  1. Everything has to get expensive....................I mean everything All I wanted to do was replace the vacume hoses and paint my valve cover red for f*** sake why does everything have to brake the $100 mark well since I have already broke that amount with all three vacume hoses, valve cover gasket, thermostate + gasket, anti freeze, paint and serpintine belt :mad: I might as well get somthing els I wanted I want to get a new oil cap like a red billit alluminum one or whatever so please give me some ideas for that ....thanks :cheers:
  2. Ok I thought back to when I was doing ball joints and had to just give in and not cheep out this time so here is what I ordered. Here It Is Your Right Maddzz
  3. Yeah, don't do it. Spend the $40 bucks for the felpro one; you won't regret it. Bad experience????? I don't have the coin$$$$$$$ already have a tube of rtv any words of wisdom on using it?? :cheers:
  4. mjeff87 Dude Good job with the colors of that engine if you ever get stuck in the woods you can signal planes with it. Seriously cool paint job I like it, and I know off topic. I couldnt resist
  5. I'm sorry but that is one of the funniest things ever sounds like a prank or something. lol sorry Pete not making fun of you sounds like somthing I would try. :laughin:
  6. Also I am planning on using hightemp rtv gasket maker for my valve cover gasket; does any one have any thoughts that they would like to share on that???? :cheers:
  7. I'm thinking Red cover and black bolts :brows: :cheers:
  8. I am going to take my valve cover off to paint it red, and replace the lines that are going to it. My question is do those bolts need to be replaced or can I just reuse them? :???:
  9. Well Ok then It does work and that is the right part right???
  10. Well My link sucks then???? It Works for me But I made it so IDK :roll:
  11. Well I hope that works <>
  12. How do you do a link because I found the rear one
  13. jeep_freek88
    Newbie
    :agree: :USAflag:
  14. When my clutch master failed there was brake fluid all over my fuse panel. you should check to see if there is any brake fluid in your cab by the fuse panel or around the dust cover on the master in the cab. Also Is there a chance that the previous owner let it run down to low and got air in the line before she refilled it? It could be that she lost the cap and all the fluid spilled out then she just refilled it without bleeding the system???
  15. Wow thats pretty massive Throttle have you seen pics of hog zilla ever......do you think it is real?? thats crazy stuff it was estimated to weigh 1,051 pounds :eek:
  16. Small tender tasty hogs mmmmmmm good luck, but you shouldn't need it though :cheers:
  17. Pete You should get a ford 460 and cram that in your jeep to match your axles then youll have lots and lots and lots of power to go along with the bad gas milage.........Hmm do you think it is possible to put a 460 into a MJ???? :???: I WONDER :brows:
  18. It starts on the 1st!!!!!!!!! Who all hunts. I would like to know what you hunt for.... so that is what this post is for I will start a new post for hunting pics later this season. :USAflag: Ok ill start I hunt Dove, upland birds, waterfoul, deer (white tail and Mule deer), elk, and pretty much anything els you can think of that is legal. I have my own bird dog(duke-chocolate lab) and all required guns and 2 bows 1 for deer and elk and the other for fishing. :USAflag:
  19. Stupid :rotf:
  20. The results are in its a rubber ape sute no joke it was on the news and the dudes responsible are being sued! :fool: :nuts:
  21. Wow here is a smiley face dipiction of what happened since we are all being so creative... :cheers: :beerhead: :driving: :fool: :drool: :wall: into a brick wall backwards
  22. I was having the same problem with my mj a couple years back. It turned out to be the fuel pressure regulator on the fuel rail. It would start fine and run great for like 10-20 minutes then studder a little bit lose power and die. I would let it sit for like an hour or two and it would start back up again. Good luck :wrench:
  23. I don't want this one to be extreme It will see a lot of road use and mountain trails for hunting. I want another truck to make huge.
  24. No one will answer my calls :mad: :redX:
