thejum57
Everything posted by thejum57
I know I'm missing something. I've been trying to post a couple of pics from photobucket, but when I try to click on the links, nothing happens. Is there something I'm missing??
I just removed one of the rear fender flares to get at the rust. All of the nuts snapped off (surprise) and I tried to get the remaining pieces out of the brackets . It looks like they are part of the bracket. Can they be removed or do I need to find some replacements? Or maybe just use nuts, bolts & washers to re-attatch? This is what I found under the flares. I don't think it looks to bad for an 86, what do you guys think?
I have an 86 with the 2.5. I cracked the valve cover a little changing the gasket. My neice gave me a steel one but it's different. this is the one on the truck this is the replacement, I'm guessing the hole at the back is for the pcv valve, would that little nipple thing on the right side be for the hose at the rear of the original? And can that be adapted? Thanks
Are the Comanche doors the same size as a 4 door Cherokee??? I need a seal for the bottom of the window and Quadratec has them listed for $10.99, but specifies 4 door only. Thanks!
I just lost the rubber seal that goes on the outside of the door at the bottom of the window. It's been loose since I bought the truck, now it's gone. I hope you know what I mean, and does anyone have one for sale?
1986 Starter Sylenoid Parts Search
thejum57 replied to thejum57's topic in MJ Tech: Modification and Repairs
It seems that the AAA guy got it wrong. I needed a starter relay. Replaced that, still no go. Got a new battery, old one was 5 years old, started right up!!!! -
Having a real hard time trying to transfer pics. Does the Ford remote style have one big lug, and 3 "push-pull" l connectors? And if so, have you used one? Part store's and or part numbers? Thanks for your help, but I've searched local parts stores and got the same answer...maybe Ford part? Also, do these have to be "stock" parts or can you substitute with an "it fits/it works part:? Or I guess I'm also asking...is a relay , a relay ? Thanks, Jim -
It's mounted on the inner fender near the battery, has about 5 leads hooked up to a post and 3 push pull connectors. Got home today (drove the other vehicle to work) it started right up. Pulled off all the leads carefully (didn't mix them up) cleaned them and ...nothing. Charged it a bit, still nothing. I need to get a new one. Don't want to pay $100.00 though! I'll get a pic up ASAP. -
Drove the truck home from work, stopped on the way went to start it ...nothing. AAA comes tries to jump it...nothing, then the guy gets a screwdriver and starts tapping on the sylenoid and it fires right up. He said I probably need a new one.The NAPA guy said he shows a Ford one for $25.00. Can they be interchanged? I know if I buy it and it doesn't work it's still mine, places won't take back electrical parts. Advance has the right one (I guess) for $100.00 and won't get it until Friday. By the way it has the 2.5l gas engine.
Is the location of the "rear speakers" in a Comanche that "grill" at the bottom of the plastic panels where the seat belts are? I want to buy new speakers and want to install them in the right spot. Thanks
cruiser54, AWESOME description! Thank you so much. When I looked at the replys, I was almost expecting "up, or down". I tightened them, and the e-brake still doesn't hold. I'm going to try it again. Thanks!
I have a 1986 Comanche,I need to adjust the rear drum brakes , to save myself some time....which direction do I need to go .....up / or down, to tighten the brakes?
Last year I replaced the rear brakes on the Comanche, new e-brake cable too. MA state inspection said "it doesn't hold". Adjusted the new shoes so friggin' tight the truck barely moved, well they were tight. Finally passed. This year...same thing...."it doesn't hold". Really? I know MA is an A-Hole about inspections but come on!!!! Are there any tricks to get this thing to hold? Thanks, Jim
jimoshel, the second set of pics with the holes for the lug nuts is what I have. Yes they have the metal clips, some stuck in the plastic hub caps, most stuck on the wheels themselves. I'll try the lubercant and Vicegrips. I guess I'll be needing to go the wanted section to look for some new ones. Thanks!
I have an 86 Comanche Custom with the little black "hub caps". One is on a wheel, the other three aren't. These are the little black plastic ones. They seem to have had little clips in them that attach to points on the wheel. Most of the caps don't have the clips in them, they seem to be still on the wheels. Are there any tricks to getting the clips off the wheels? I've tried vice grips etc. Does anyone have pics of the back of the hub caps with the clips in place?
How exactly do those little "hub cap" things attach to the wheels? I have rusty little nubs on my wheels I don't know how to get off. I have 3 hubcaps with empty little holes. I'm guessing the hubcaps have little things in them that clip on to the wheels?
I replaced my wiper motor last weekend...AWESOME write-ups in the DIY section. I had no problems at all removing and replaceing it. I also replaced the bushings as was suggested. The first rain was great, they wiped like champs. But yesterday on the way to work....in the dark... they worked fine until about a 1/2 mile from work, where they stopped mid-wipe, started after a bit, then stopped, etc. This is just whay they were doing before!!! Is there someting else to check? Thanks, Jim
Windshield Wiper Arm Removal
My Bad...I reread them and the arm removal is one of the first pics. Lesson learned.....don't drink and post without carefully reading first. It's been a long week! -
I will be replacing the wiper motor in my truck this weekend. I've read the DIY writeups but did'nt see anything about removing the wiper arms. Do you just pry out that clip at the stalk, or is there a trick to it? Thanks, Jim
Renix box inside cab? rattling
This would be what is inside the box maybe? There was a pic, but it didn't copy. Cardone Reman/Engine Control Computer Part Number: 79-2099 Warranty: 1 YR Application: With manual transmission Notes: Units are pre-programmed at the factory and ready for installation with no further programming required. Price: $73.99 +Core: A "Core" is an item that has the ability to be rebuilt by the manufacturer using new replacement parts. Rebuilding these items helps to reduce product cost as well as aid in recycling efforts which helps the environment. When the old part is returned to AutoZone, we refund the core charge to you. $30.00 STORE PICK UP SPECIAL ORDERSHIP TO HOME AVAILABLE -
Duh for me on the hose, I should have figured that out! Well it sounds like the ecu tells the engine what to do. Could certainly explain the on / off performance issues. I don't want to ask, but that's probly an expensive item to replace? Also probly be a dealer item (yikes). Would you just remove the cover and replace a unit inside, like a circut board or something? -
I kept hearing a rattle under the dash (86 Comanche 2.5, 5 spd ) tracked it down to a box mounted to the left of the ashtray. It says Renix on it, with a large bundle of wires coming out of it. The manuals I have says it is located near the battery. I've felt around, and nothing seems to be loose. There is what seems to be a plate it is attachet to. I tie wired it tight and it seems to have stopped rattlaling. The truck also stumbles / hestates while driving. As of today it does'nt. Any coments...sugestions? Pics And what the heck does this hose do??? Thanks people! Jim
Does anyone have 2 equalizer bars with working springs for rear drum brakes for an 86 Comanche? The po of mine or someone welded the springs so they can't move. I was replacing the rear shoes, and the brakes won't compress enough to get the drum on. A guy who does brakes for a living pointed out the welds and said the spring should be able to compress. Parts stores have no listings and suggest junk yards. The few junk yards so no. :ack:
Does anyone know where I can find the equalizer bars for the e-brake for my 86 Comanche? I talked to a guy from Auto Z...and he really knew his stuff, he also owns a Wrangler, but no match in the store. He did a lot of work trying to help me, but couldn't. Any help would be apreciated. The springs at the back of mine were welded by a PO. Who knows why. I was doing a brake job, and the shoes would not compress enough to put the drum back on...a 2nd opinion pointed out that the springs were welded on. What The ???? Also, I removed ALL of the lug nuts last Sat., spent about an hour hacking, tearing & ripping off that tin crap that passes for CHROME. Got them all off, greesed them and put them back on. So tonight all but one came off......one week!!!!!! It striped! I spent about an hour and a 1/2 hammering/chisinig to get it off while my buddy was trying to figure out why the drum wouldnt fit back on. Pics to come! After 4 hours we called it a night. A great end to a long week. :cheers:
