ironhead03
Everything posted by ironhead03
Advance auto has them.
Need help with starting issues in N.E. Ohio
ironhead03 replied to ironhead03's topic in MJ Tech: Modification and Repairs
Does it include a crank sensor,any idea how much it is? Thanks Yes, it can still be purchased. The Chrysler part # is 83100066 -
I just read another thread about a crank sensor patch kit.Could this be my problem and is it something i can still buy? -
It has new cap,wires,rotor and plugs. I think i have an extra coil,i'll try changing it and spring for a new CPS. -
I have'nt checked the fuel pressure but it has a new pump in it. My wiring harness is not the orginal one, it does'nt have the ballast resistor. And it has new o-rings on the injectors and no smoke on start up. Sometimes it will do a loud backfire before it finally starts, but not to often. -
Does anyone live close to Ashtabula that would be willing to come to my house and help me fix my 89 MJ? I would gladly pay you to help me get my starting issues fixed. I have to crank it for several minutes to get it started. After it starts and runs for a minute if i shut it off it will start again in about 5 seconds of cranking. The starting issues have put a stop to my to do list for the winter on the truck.
Hey Willy Hope you do'nt mind me asking questions.Did the 231 yoke bolt right on to the Mazda shaft or did you have to do some machine work? Thanks. Gary
- 897 replies
- dana 44/8.8
- arb lockers
- (and 3 more)
- 897 replies
- dana 44/8.8
- arb lockers
- (and 3 more)
Anyone running a box4rocks 231 doubler?
Thanks Willy. It's the stock bracket that the shift linkage pivots on. I just drilled a hole in the appropriate place in the brackets and welded a bolt in for my shifters to pivot on. The shafts that come up through the floor? They are solid rod I picked up at the hardware store and bent to the necessary shape. Also found the shift knobs at the hardware store. Willy -
Nice job on the shifters.Can you give me any more info on them? Did you make the plate that bolts to the tranny or is it something i can buy? What are the shafts off of? They really look good? Thanks. Gary -
Seems like i remember someone saying that the 97-98 XJ door seals will work on our MJ's and are thicker. Can anyone confirm this for me? Can anyone get their hands on a set for me? Thanks
Input wanted,new bearings or new block?
Sounds like your the guy i want to talk to. I thought the exhaust header changed around 90 or 91. Do you know if my distributor and oil pan will work in the 97? All i would be getting with the 97 is a bare block and head.I had sold this block to a kid early in 2008 and know the history on the motor,its a real good donor.Sounds like this may be my best choice. Thanks for any help you could give me. -
I have plenty of time.I'm retired and have just started taking stuff off the truck to do the body work and put a paint job on it this winter.It's strickly an offroader. As for tools i got more than i would care to count and plenty of skill,i just do'nt have the knowledge about the swap. Will my head off the 89 bolt onto the 97 block without any modifications?Which push rods would i use? -
I have the same problem as some of the guys on here with low oil pressure on my 4.0 after it warms up. I have been debating on wether i should put new rod and main bearings in the truck or a different block. I can get my hands on a low milage 4.0 out of a 97 tj. Has anyone done this. Would i be able to bolt all of my componets on to the 97 block and head? Would i run into any problems? I have an automatic in my truck. My motor is an 89.Thanks for any help
12 pounds of oil pressure...
ironhead03 replied to BLHTAZ's topic in MJ Tech: Modification and Repairs
Can anyone post a pic of where the codes are stamped into the block? I need to do my bearings also but i ca'nt find anything on the block. Thanks. -
Where did you get the bearings from for a hundred? Thanks -
Who was the club member at Jeepfest
I do'nt think he had a truck there. He said he had two of them and was working on one of them i believe. Were you there Saturday? -
Just wanted to know who the fellow member was that i talked to at Jeepfest on Saturday? I had one of my magnets on the side of the truck and met a guy and talked for a while.Had a great time and the truck was awsome,first time out for me with it and had no problems at all. I did'nt get it ready until 6 o'clock friday afternoon.
wire harness swap question
ironhead03 replied to twojeeps's topic in MJ Tech: Modification and Repairs
When i did mine a few months ago i had to use the xj harness going back to the pump and lights and splice them into the mj wires. I swaped a 89 xj dash and harness into my mj. The xj has alot of wires you wo'nt need depending on all of the options it had. Like power windows and seats. -
Whats this bracket for?
Sorry about that.I ca'nt figure out how to add the picture.[/url] -
Can anyone tell me what this bracket is for? Its the one that i'm pointing at with the magnet. Its on the front of the truck behind the bottom of the radiator. Thanks.
anti-seizing brake lines
ironhead03 replied to jtdesigns's topic in MJ Tech: Modification and Repairs
x2 what eagle said. It's great stuff,i use it on everything.
