Kona
Everything posted by Kona
  1. Kona
    Clusters
    Need one!
  2. Anyone had this before? I never had, I have this ticking noise coming from the valve cover after the engine is off, like heat noise but it happens even after start and shut off , almost like a valve trying to move or a rod trying to move, any ideas ?
  3. All good things to look for, all grounds seem To Be in place, but I'll re check, I'm waiting in the "new TCU" we will see if that fixes it, I think is the TCU just because my buddy just threw the thing on the floor like it was garbage so maybe it got banged up and damaged inside.
  4. Good idea!, didn't think about that, I'll check that tomorrow and get back to you all. Thanks
  5. Update: I bought a new TPS and plugged the TCU back and.... Still does the same thing , stuck in first gear, unplugged theTCU and fine! (manually) so I guess need a new TCU? Found one on eBay from a 89 xj, will this work?
  6. Thanks for the info, I'm still debating on that, keep the bench or buckets.
  7. Hi y'all, so picked up a pair of buckets from a 01 XJ, anyone done this swap? Thinking grind the brackets of the bench and weld to the XJ seat with some obvious mods since its wider, will it be to high in the cab?
  8. Pics? I got one and was thinking about installing.
  9. TCU? Check voltage on the TPS.
  10. Done with paint!
  11. Got it fixed and got some cosmetic done!
  12. Unplugged the TCU and I'm able to shift manually no problem, could it be the TPS? Or jut need a new TCU?
  13. Could it be the TPS? All is hooked links, I have done this several times an never had a problem, now the TPS when unplugged does not affect the idle, so I'm thinking the tps is fried! My understanding is that TPS will cause this as well. Anyone had this?
  14. Hi guys, so I got a 87 mj column shift , I redone the engine and it runs great!, redone the tranny seal and filter , now the truck won't shift ? Stays in first gear , it shifted fine before the maintance , fluids are good, my question is did I maybe forgot to plug something? Connector ? Or did I just f-up the tranny by replacing fluids and filter? It's just weird it won't shift now, any ideas on what to check or do other than a new tranny? Thanks!
  15. Hi guys like I said in the other post I'm new to the forum, this is ma new addition to my jeep collection , 87 MJ 4x4, 6cyl short bed , I've had Kona for a week, here's what I've done so far, engine and tranny and all seals and gaskets, all new vacuum lines, swapping interior to bucket seats and a lot more to do. Got her running yesterday and runs beautiful !
  16. Hi ya'll from nashville Tn, I'm new to forum, long time jeep owner, recently got a 87 MJ short bed 4x4 6 cyl. Column shift, I am getting Her back to life, got the engine redone and running yesterday, will post pics soon . Awesome site!!
