ja_racing
Everything posted by ja_racing
  1. Anyone familiar with what exactly the rem codes mean new to me just installed one and have 2 codes pop up periodically in the morning only
  2. I'm having a similar issue just got the rem installed i hear it ping a little one a load high gear when i want to accelerate more i have 50 psi fuel pressure I'm going to check for vaccum leaks and also my iac not working properly rn
  3. I'm going to try standard ac151
  4. Idle is crazy now maybe it wasnt to good a iac after all ill buy a new one and try it out again
  5. I just threw a 95 cherokee iac on my ho tb and its idles good so ho iac does work with renix harness just did it last night since before had my iac sealed and connector unplugged and just turned the screw to raise the idle now ho iac with renix harness and backed out butterfly bolt to cruisers butterfly adjustment and seems to be fine so far
  6. Ive had my iac disconnected i have a ho tb will the renix wiring control the ho iac correctly?
  7. So the ho iac will work with the renix harness
  8. Can anyone take a pic of the wires or know how they go for the stator pickup i need to install a plug on my harness to connect it its cut off
  9. Anyone that can take a pic pf the plug for the stator that goes on the distributor from the harness to see what wire goes on what to re wire my plug
  10. Awesome this will definitely help thanks
  11. Anyone know the oxygen sensor wire colors coming from the firewall wiring harness mine are cut off and trying to figure out the wires to install a oxygen sensor
  12. Found a local one thanks!
  13. Clear trim
  14. Need a passenger side tail light
  15. I have some ill be removing
  16. How do you do that? Is there a thread or write up that would be cool 97+ windows in old doors
  17. Have all led up front and my flasher works but my turn signal arrows in gauge cluster stay on when not using turn signal when lights are on
  18. Anyone try the ebay carpet for a comanche? if so how was the fit or anyplace to buy new carpet thats recommended
  19. Ok thanks
  20. Can u send me pics
  21. Yea i kno just want to put 1 for now and after i paint the comanche buying a new set
  22. Yea how much u asking for it
  23. Looking for a rear passenger tail light
