Bhfear Posted June 9, 2012 Share Posted June 9, 2012 I just can't tell in the pictures, can you guys tell me what it is? Link to comment Share on other sites More sharing options...
landlubber Posted June 9, 2012 Share Posted June 9, 2012 here is an AX-5 and a AX-15 side by side Link to comment Share on other sites More sharing options...
Pete M Posted June 9, 2012 Share Posted June 9, 2012 if I remember right, the big ring o' metal right in front of the shifter handle is steel on the AX-5 and aluminum on the AX-15. :thumbsup: Link to comment Share on other sites More sharing options...
Bhfear Posted June 9, 2012 Author Share Posted June 9, 2012 In that picture you posted which one is the ax15, and these are pictures I am going off from a local seller that has no idea what he has for sale, so hes no help, and I havnt seen it in person to check what that ring is made of. Link to comment Share on other sites More sharing options...
Bhfear Posted June 9, 2012 Author Share Posted June 9, 2012 I'm 80% sure its an ax15 but just wanted to make sure, before i made the drive Link to comment Share on other sites More sharing options...
landlubber Posted June 9, 2012 Share Posted June 9, 2012 stole it from a thread on naxja http://www.naxja.org/forum/showthread.php?t=956031 the AX15 is the shiny one on the left. if a conclusion cannot be made from the pictures, maybe ask for dimensions? Link to comment Share on other sites More sharing options...
Pete M Posted June 9, 2012 Share Posted June 9, 2012 the part number shows it as a 94-96 AX-15. :thumbsup: Link to comment Share on other sites More sharing options...
Geonovast Posted June 9, 2012 Share Posted June 9, 2012 I am 100% sure that is a 4.0 bellhousing. It's an AX-15. landlubber's picture is misleading, as they are an AX-5 and AX-15 next to each other, but they both have a 2.5 bell. Link to comment Share on other sites More sharing options...
landlubber Posted June 10, 2012 Share Posted June 10, 2012 I am 100% sure that is a 4.0 bellhousing. It's an AX-15. landlubber's picture is misleading, as they are an AX-5 and AX-15 next to each other, but they both have a 2.5 bell. thought it looked a bit odd Link to comment Share on other sites More sharing options...
my86mj Posted June 11, 2012 Share Posted June 11, 2012 is it possible to run a ax15 on a 2.8? i was thinking of beefing up my drivetrain before a motor swap Link to comment Share on other sites More sharing options...
Pete M Posted June 11, 2012 Share Posted June 11, 2012 yes. works the same as the 2.5L using the Dakota bellhousing trick. Link to comment Share on other sites More sharing options...
