Testing an AW4
Not really. The diagnostic and operability checks are all done w. the tranny installed. About all you can do is pull the pan, check the condition of the fluid and for any metal pieces in the filter. I can send you the AW4 manual if you want it.
When I drained the fluid it looked clean and had no "burnt" smell. I'll pull the pan and take a look inside. This will be for sale if anyone needs one (cheap!!!!)
