Probably not much help, but red and yellow are your constant and switched power wires, and as you know, black is ground. I just hook them 3 up, then power the deck up, switch the balance and fader to say, the left rear speaker, and just go nuts touching wires together until that speaker works. Then switch the deck to a different speaker and repeat. :eek:
It all depends on the year of your MJ.
Here's a good site to get you in the right direction, even though it was wrong about my 92 MJ.
My constant wire is pink. I had to search for the particular application where it was pink. And I found the correct wiring under "93-94 Cherokee". Sure enough, that worked for my 92.
http://www.the12volt.com/installbay/veh ... /Jeep.html
Go by the harness connector pin numbers and function. Wire colors changed throughout the years, but the plug pin numbers and function on each pin did not.
