Removing Emblems and Letters prior to paint?
Getting ready to do some body work and paint to me Comanche. My question is, how do you remove the Comanche Emblems and Jeep letters off of the body without breaking them? Also, can they be re-attached with glue or adhesive?
Thank you for your advice.
Guest vzehler
you should be able to get them off pretty easily by carefully taking a razor blade between the emblem and the sheet metal. Use a double sided foam tape to re-use the old ones.. I wouldn't recommend glueing them, they'll never come off.
you should be able to get them off pretty easily by carefully taking a razor blade between the emblem and the sheet metal. I personally would just buy new ones as inexpensively as they can be obtained. Or use a double sided foam tape to re-use the old ones.. I wouldn't recommend glueing them, they'll never come off.
Do pins hold them on or are they bolted on? I am talking about the 4.0 , Jeep, and Comanche emblems or logos.
Thanks again.
