tkgibbs27 Posted June 5, 2008 Share Posted June 5, 2008 The outside dimensions are 60" wide X 76" long at the bottom. The heighth is 19". http://kpr.craigslist.org/pts/701885407.html Link to comment Share on other sites More sharing options...
Eagle Posted June 5, 2008 Share Posted June 5, 2008 Search is your friend: http://comancheclub.com/forums/viewtopi ... dimensions Link to comment Share on other sites More sharing options...
tkgibbs27 Posted June 5, 2008 Author Share Posted June 5, 2008 i got the sb though Link to comment Share on other sites More sharing options...
Geonovast Posted June 5, 2008 Share Posted June 5, 2008 i got the sb though You should probably specifimify in either the post or your sig then. Link to comment Share on other sites More sharing options...
Eagle Posted June 5, 2008 Share Posted June 5, 2008 Why not measure your own truck, since you have the dimensions of the cap? Conventional wisdom is that older Chevy S-10 caps fit MJs. Link to comment Share on other sites More sharing options...
tkgibbs27 Posted June 5, 2008 Author Share Posted June 5, 2008 we are moving, so all the tools are already packed up and in florida, so i don't have a tape measure around. Link to comment Share on other sites More sharing options...
fiatslug87 Posted June 5, 2008 Share Posted June 5, 2008 The inner measurements at the top of the bed (inside the front rail to the tailgate) of mine are: SWB 73" x 55" (outer: 60" from flat portions of side rails) Add a couple of inches for the front rail and the tailgate. 19" high puts you at about the top of the rear window gasket in the center. Link to comment Share on other sites More sharing options...
tkgibbs27 Posted June 5, 2008 Author Share Posted June 5, 2008 not high enough. Link to comment Share on other sites More sharing options...
