Tranny swap
Here is my situation. I have a 90 AW4 with np231, with a SYE insatlled in the garage. MY question is what all do I need to swap that into the Turd, which has the beloved puke goat in it.
I got the the TCU from a 1987, but not sure of everything I need to pull this swap off.
Any help would be great.
Besides the Transmission??
Change out the flywheel > Flex plate
TV cable and bracket/linkage at the TB.
Change out the TPS.
Auto shift cable, and if you want......lock out cable from steering column.
Floor shifter......or change out the steering column for a column shift :roll:
Change out the floor peddles, unless you have a use for the clutch pedal :brows:
Rear drive shaft, different length.
Oh.....and transmission mount at the cross member.
And I'm thinking that the wiring harness is the same for the TCU to plug and play.
I thing I got it all ;)
Easy job.......for you Pat :D
Change out the TPS.
I did this conversion on my sons 90 - which had an ax15.
- You have to replace the throttle body. The one they used with the manual does not have the place to hook up the TV cable
--The complete tranny wiring harness. There are wires to a second output on the auto TPS, and to the brake pedal. Make sure you get the harness from a Renix era Jeep, the TCU connectors are different in the 91+.
Basically I am going to take whatever parts I need Of Of Pongs Old motor :eek: The 4.0 isnt staying in there :brows:
So basically I need the wiring harness all the cables hooked to the auto tranny, Flex plate/flywheel.. a floor shifter and I am good? I think I have all that laying around :oops:
AS for the driveshaft... I have Pongs old one.. which if too long.. will be retubed and shortened :nuts: and if that doesnt work... I have a few spare ford, jeep, and IH shafts laying around :eek:
