pingpong Posted May 15, 2008 Share Posted May 15, 2008 I was wondering if there was a website so I could figure out what d44 carrier I got with a lock right I bought. Or where the numbers should/would be to tell me. Link to comment Share on other sites More sharing options...
Pete M Posted May 15, 2008 Share Posted May 15, 2008 The guys at ring-pinion.com might know. If you find some part numbers, you could do what I usually do and punch the numbers into google and see what comes up. :D Link to comment Share on other sites More sharing options...
JOMJ87 Posted May 15, 2008 Share Posted May 15, 2008 The mssurements from the ring mounting surface to the bearing should be different between the two that are offered. Here is a link to a similar question on a 44. http://www.rrorc.com/forums/showthread.php?t=34832 Cole Link to comment Share on other sites More sharing options...
pingpong Posted May 16, 2008 Author Share Posted May 16, 2008 Thanks.... I got a set of thick gears.. so I will just uninstal the lock right in the other carrier and install my gears on the carrier I know it will work on... Installing lock rights isnt that hard.. especially when doing it on a bench Link to comment Share on other sites More sharing options...
JOMJ87 Posted May 16, 2008 Share Posted May 16, 2008 Yeah they are quick and easy until you let a spring fly across the room on you. Cole Link to comment Share on other sites More sharing options...
mvusse Posted May 16, 2008 Share Posted May 16, 2008 Yeah they are quick and easy until you let a spring fly across the room on you. Cole You speaking from experience? :D Link to comment Share on other sites More sharing options...
