djag12 Posted May 14, 2008 Posted May 14, 2008 How do you take them off. Are they bolted from the inner well?
JOMJ87 Posted May 14, 2008 Posted May 14, 2008 Yes there are studs sticking thru and nuts on the inner side of the fender. Easy to reach but they can break easy also. Cole
fiatslug87 Posted May 14, 2008 Posted May 14, 2008 There are three metal plates per flare with 3 studs each. When I removed mine several did break so I ground their heads off and popped them out and then brazed new bolts through the holes. Others have just used bolts/washers/nuts without the plates.
djag12 Posted May 14, 2008 Author Posted May 14, 2008 Thanks. I broke every bolt so far. One good thing is no rust so far
