possum Posted May 8, 2008 Share Posted May 8, 2008 I don't have a picture right now but does anyone have a little check valve looking thing on the inlet heater hose? If so do you know what it is for? It was leaking and I am gonna do something with my heater hoses other than run them to the heater core. So should I keep it so I can get another or can I just eliminate it completely? My truck was originally a 2.8 2wd. It is now a 5.7 2wd. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
maddzz1 Posted May 8, 2008 Share Posted May 8, 2008 That is the heater control valve. You can replace the whole assembly in one piece it the tee thing is bad too. http://www.teamcherokee.com/AC_and_Heating/index.html Link to comment Share on other sites More sharing options...
mjeff87 Posted May 8, 2008 Share Posted May 8, 2008 It's a vaccuum operated valve that allows coolant flow to the heater core. When you slide the temp control on the heater control over to hot, you also are sending a vac signal to it to open up. When it's set to cold, coolant doesn't circulate thru the core. You can eliminate it, you'll just have your core active all the time. It may be a bit warmer inside the cab in the summer, though. Jeff Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 8, 2008 Share Posted May 8, 2008 It's a vaccuum operated valve that allows coolant flow to the heater core. When you slide the temp control on the heater control over to hot, you also are sending a vac signal to it to open up. When it's set to cold, coolant doesn't circulate thru the core. You can eliminate it, you'll just have your core active all the time. It may be a bit warmer inside the cab in the summer, though. Jeff Since the 1997+ XJs don't have the water valve, I eliminated it and plugged the vacuum line. No difference in the cab temps. Link to comment Share on other sites More sharing options...
Motion Offroad Posted May 8, 2008 Share Posted May 8, 2008 And lastly... You can get one from the 91+ XJ's. The part number is 56005900. Link to comment Share on other sites More sharing options...
possum Posted May 8, 2008 Author Share Posted May 8, 2008 Thanks guys. Looks like I am gonna get rid of it. If you didn't see the rear radiator thread I am gonna run my heater hoses to a heater core mounted in the front so no coolant will be flowing through the cab heater core until winter. :cheers: Link to comment Share on other sites More sharing options...
